997.1 turbo Rattling sound at rear
Old Feb 26, 2014 | 12:34 PM
ChrisAW's Avatar
ChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to beholdChrisAW is a splendid one to behold
I have something similar. Rattle or clatter sound coming from the engine at low load and low RPM. My dealer noticed it too and they are checking it out right now. I love my CPO warranty!
I'll update with what they find.
Old Feb 26, 2014 | 01:57 PM
Boeing Driver's Avatar
Boeing Driver is infamous around these parts
Its normal, if they don't know about it I wouldn't even let them touch the car.
Old Feb 26, 2014 | 02:21 PM
jhbrennan's Avatar
Sounds like the normal "Mezger Sound" - read this -
File Type: pdf
Old Feb 26, 2014 | 02:22 PM
997ttR's Avatar
997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light997ttR is a glorious beacon of light
I have something similar. Rattle or clatter sound coming from the engine at low load and low RPM. My dealer noticed it too and they are checking it out right now. I love my CPO warranty! I'll update with what they find.
Please Keep us posted.....
Old Feb 27, 2014 | 01:00 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
On occasion, I have had a rattle coming from the rear of the car as well on start-up and during initial idle. It always seems to be one of two things:
1) The heat shield around the exhaust tips (inside the rear bumper liner) sometimes gets a little tweaked and comes just close enough to touch and vibrate on the exhaust system on start-up and at certain rpm's.
2) The dust shield behind the rear rotors occasionally gets tweaked as well from road debris and will actually vibrate against the rotor when you first start the car (hard/rough idle). It has a very distinct sound. One way to confirm this is while driving at very low speeds with your windows down, turn the vehicle left and then right, if you hear a rubbing sound or something vibrating as you are turning, it will most likely be the dust shield barely touching the rotor under load.
Hope this helps?
Old Feb 27, 2014 | 05:45 PM
997ttR's Avatar
Originally Posted by VID997
On occasion, I have had a rattle coming from the rear of the car as well on start-up and during initial idle. It always seems to be one of two things: 1) The heat shield around the exhaust tips (inside the rear bumper liner) sometimes gets a little tweaked and comes just close enough to touch and vibrate on the exhaust system on start-up and at certain rpm's. 2) The dust shield behind the rear rotors occasionally gets tweaked as well from road debris and will actually vibrate against the rotor when you first start the car (hard/rough idle). It has a very distinct sound. One way to confirm this is while driving at very low speeds with your windows down, turn the vehicle left and then right, if you hear a rubbing sound or something vibrating as you are turning, it will most likely be the dust shield barely touching the rotor under load. Hope this helps?
Thank you!
Old Feb 27, 2014 | 09:32 PM
flyjets's Avatar
flyjets is infamous around these parts
The Rattling noise your speaking of is below 2000 RPM correct?
Its the IMS shaft all normal. The IMS is gear driven on all the GT1 blocks. While slightly different on a GT3 still gear driven.
My advice rev your engine more or get a slighly louder exhaust.
The Mezger engine is worth it.
Ian
Old Feb 27, 2014 | 11:21 PM
997ttR's Avatar
Originally Posted by flyjets
The Rattling noise your speaking of is below 2000 RPM correct? Its the IMS shaft all normal. The IMS is gear driven on all the GT1 blocks. While slightly different on a GT3 still gear driven. My advice rev your engine more or get a slighly louder exhaust. The Mezger engine is worth it. Ian
Yes, looks like it is at low RPM's and I actually just installed straight pipes today and haven't put attention to the rattling, I'll check tomorrow
Thanks.
Old Feb 27, 2014 | 11:22 PM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
I have been fighting what I described as a gnome in my engine bay clacking two hammers together for a while now.
I think it's been found now though, the issue appears to have been caused when the engine was lowered to install AMS Inlet pipes they (my local shop, not AMS) pulled some of the coolant lines out of the guides towards the front of the car under the aero shielding.
That was the explanation I got today, I'm going in the morning to pick it up and give it a listen. I have some video of what it sounds like from the drivers seat I'll post it.
I've heard the usual Metzger rattle, and exaust rattle. This one was totally different and sounded VERY bad. It *only* occurs under heavy load too which made it pretty bizarre.
Old Feb 27, 2014 | 11:25 PM
997ttR's Avatar
Originally Posted by rix
I have been fighting what I described as a gnome in my engine bay clacking two hammers together for a while now. I think it's been found now though, the issue appears to have been caused when the engine was lowered to install AMS Inlet pipes they (my local shop, not AMS) pulled some of the coolant lines out of the guides towards the front of the car under the aero shielding. That was the explanation I got today, I'm going in the morning to pick it up and give it a listen. I have some video of what it sounds like from the drivers seat I'll post it. I've heard the usual Metzger rattle, and exaust rattle. This one was totally different and sounded VERY bad. It *only* occurs under heavy load too which made it pretty bizarre.
Keep us informed
Old Feb 28, 2014 | 10:06 PM
deantube's Avatar
deantube is infamous around these partsdeantube is infamous around these parts
I purchased my 2007 last November, with only 15k miles on it. It took about a month for me to notice a rattle from the rear. I first noticed the rattle when I was driving through a parking lot. I didn't give it much thought because I didn't notice it all the time. For the last month, I've been trying to figure out when I start to hear the rattle. It begins to rattle after the car has warmed up, when just starting off from a stop or from a very low speed. It happens at about 1800 rpm. I can't tell if the rattle subsides after that rpm level because there's more noise from the exhaust that might be covering up the rattle. It definitely doesn't occur below 1800 rpm.
I put the car in park a few times and revved the engine very slowly to just past 1800 rpms. I didn't hear the rattle at all. The engine sounded really good. This has me thinking that it might have something to do with the transmission.
A couple of days ago, I took it to an very well known independent Porsche only shop for an oil change, brake flush, and typical visual/DME inspection. I mentioned the rattle to them, but when I went to pickup my car later that day, they didn't say anything about a rattle and I forgot to ask. I have an extended warranty on it, so I might take it to the dealer. I'll post on this forum again if and when I do take it to the dealer.
Old Feb 28, 2014 | 10:20 PM
997ttR's Avatar
That will be nice.
Old Mar 1, 2014 | 10:44 AM
rix's Avatar
rix
Originally Posted by 997ttR
Keep us informed
I got the car back yesterday with the same noise. Pretty bummed out about it now. I have to travel for business the next few weeks so I doubt I'm going to make any progress for a while.
Old Mar 1, 2014 | 11:00 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Rix,
The noise are you talking about. Does it sound like a very loud metallic popping sound at full throttle and peak torque? Easy2Speeds car does this also, and we haven't been able to figure it out yet either. It sounded like something was/is hitting when the motor torques over under full load, but the motor recently came out to fix the coolant fittings and nothing was found.
I've scoured the internet and found a couple of other people who have complained of the same thing over the years, but no real solution was posted and we haven't gotten any response from those posters.
Log-wise, the pulls look perfect. No timing pull or anything, just that loud popping sound. This the same as you?
Old Mar 1, 2014 | 11:02 AM
rix's Avatar
rix
Yes, sounds like a very similar situation.
