Assisted Sachs stage 2.5 clutch...has it been done?
Old Mar 3, 2014 | 06:14 PM
brent95m3's Avatar
brent95m3 is a jewel in the roughbrent95m3 is a jewel in the roughbrent95m3 is a jewel in the roughbrent95m3 is a jewel in the rough
So a couple months ago the turbo clutch went to the floor...hydraulic clutch assist was toast and replaced under warranty.
Last week the coolant lines went (another common issue). So I figured engine out, do the clutch (I had parts waiting but figured time was right).
So now I have a brand new slave cylinder and a Sachs stage 2.5 clutch. Should I just swap the clutch out and leave the brand new slave cylinder in place?
It seems everyone does the conversion after the failure but the failure has happened and been covered by Porsche. Now I just have to pay labor for a clutch to be swapped out while engine is already out.
Thoughts?
Old Apr 29, 2014 | 02:53 PM
swole305's Avatar
swole305 has a spectacular aura aboutswole305 has a spectacular aura aboutswole305 has a spectacular aura about
I am in the same boat as you. Engine is coming out at 35K miles and since the engine is out thinking about replacing the clutch now so I don't have to worry later. My clutch is fine though at the moment.
Old Apr 29, 2014 | 04:18 PM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
What does a slave cylinder have to do with the a Sachs stage 2.5 clutch??
Either im not understanding or you don't know what your talking about.
Yes after the slave fails many people convert to gt2 (non assisted) setup. However the slave has nothing to do with your actual clutch or pulling your engine.
Old Apr 29, 2014 | 05:37 PM
L_Perm's Avatar
L_Perm is infamous around these partsL_Perm is infamous around these parts
It's been done many times from what I've gathered. Some do the GT2 conversion when they replace the clutch. Others don't. The conversion can be done without removing the engine, so see how the assisted feel is first. You can always GT2 convert later.
LP
Old Apr 30, 2014 | 12:54 AM
brent95m3's Avatar
Did it while the engine was out. I didn't do the GT2 conversion as I didn't have the parts. No issues and clutch is as light as stock with the same amount of pedal feel.
lazyseoul
May 4, 2017 10:38 AM
HIGHcard
Sep 24, 2015 08:09 PM
jyupitt1
Sep 10, 2015 08:31 PM
