Ignition
Old Apr 20, 2014 | 04:42 PM
xseal's Avatar
xseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to allxseal is a name known to all
Ignition
I have an 07 997tt. Sometimes I put the key in the ignition and it takes a minute before the car recognizes the key and the electrics light up and the starter hits. Presume this has happened to others. Perhaps battery in key dying? Remote lock/unlock works fine though.
Pls advise.
Old Apr 20, 2014 | 04:45 PM
jhbrennan's Avatar
Pls advise.
Battery in key is for the remote - has nothing to do with ignition recognizing the transponder chip in the key. Sounds like a a problem with the electronics around the ignition switch.
Old Apr 21, 2014 | 11:42 PM
Steve_TT's Avatar
Steve_TT has a spectacular aura aboutSteve_TT has a spectacular aura about
I've had this a few times. I stick the key in and turn and the electronics go off as if starting but the motor doesn't turn over. I turn off then turn on again and then it fires fine. Battery is full. Perhaps the ignition takes a moment to recognize the key chip. Not sure if I'm putting in the key and turning too fast......
airbusdrvr
Dec 27, 2015 07:43 PM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
rob4wellness
Oct 2, 2015 07:32 AM
jdubbya
Sep 28, 2015 04:58 PM
