Rear wheels flush with fender? What spacers
Old May 5, 2014 | 01:04 PM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
As the title says how do I get my rears more flush? Maybe its bad angle but it seems my wheels are a little behind it if you know what I mean
Old May 5, 2014 | 01:08 PM
maverickdxb's Avatar
maverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond reputemaverickdxb has a reputation beyond repute
15mm at the back on stock OEM wheels is ideal.
Old May 5, 2014 | 01:10 PM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
Is that enough to require longer studs? Thanks
Old May 5, 2014 | 01:15 PM
DNugget991GT3's Avatar
what kind of wheels ? what brand of tires ? are you lowered ? do you know your alignment specs ? and yes you will need longer studs with anything more than 5mm
Old May 5, 2014 | 01:16 PM
Squat's Avatar
Im all stock wheels and PS2s. Do you know of any sponsors that sell what I need? or is it Ebay time?
Old May 5, 2014 | 01:19 PM
ECS Tuning - Porsche's Avatar
Yes. The stock wheel bolts are 45mm and you would need the 60mm wheel bolts to make 15mm spacers work. We offer a few different sized kits that include everything you need, for more information Click Here.
Old May 5, 2014 | 01:36 PM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
If it is 15mm for the rear, how about the fronts?
Old May 5, 2014 | 01:40 PM
get em from ECS. they use usps priority so it gets there in 2 days.
Old May 5, 2014 | 01:41 PM
Squat's Avatar
They dont have the 15mm in stock. Wish they had otehr bolt colors... black doesnt go with stocks... oh well
Old May 5, 2014 | 02:02 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Hate to correct you guys, but that's wrong. The stock bolts are about 30mm. So for a 15mm spacer, you'd need 45mm bolts. If you try putting a 60mm bolt on with a 15mm spacer, it's going to right through and nail the hub.
Old May 5, 2014 | 02:03 PM
I've got 15's in stock with two bolt choices, black or zinc-plated.
http://www.championmotorsport.com/pr...-15spcrkit.htm
Old May 5, 2014 | 02:10 PM
You're not wrong. We include the length of the ball seat in our measurements, the 45mm is only 30mm threaded length and the 60mm would only be 45mm threaded length.
Old May 5, 2014 | 02:57 PM
kwiksilver's Avatar
kwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond repute
Most folks use 7mm on the fronts
Old May 5, 2014 | 03:02 PM
Ah ok...that makes sense then. Just keep in mind, if someone calls Porsche, the spec for the bolt according to Porsche doesn't include the length of the ball seat, so it might become misleading. I'd just use the standard method of measuring if I were you guys, to avoid any hassles. Just some friendly advice.
Old May 6, 2014 | 12:35 PM
TiKORE's Avatar
TiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of lightTiKORE is a glorious beacon of light
#welugwheels
