Tire ratio issues with 997.2
Old Jun 12, 2014 | 03:59 PM
Stage7's Avatar
Stage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond reputeStage7 has a reputation beyond repute
I read about the tire ratio requirements of the 997.1 or run the risk of differential damage.
Does the 997.2 have the same issue?
Are 245/30/20 Michelin PSS w/ 295/30/20 Michelin PSS ok? Seems about 2.5% different than factory if my math is correct.
The rear wheels are 11" wide so I'm not sure how a 325/25 wheel would fit/look.
Old Jun 13, 2014 | 06:22 PM
Stage7's Avatar
I guess no issue with the 997.2?
Old Jun 14, 2014 | 10:02 AM
Steve_TT's Avatar
Steve_TT has a spectacular aura aboutSteve_TT has a spectacular aura about
I haven't heard otherwise so I'd assume the same issue as the 997.1.
On your tire sizes, circumferences look to technically work, but overall look and handling may seem odd (wider in front, narrower/taller in rear). If you are intent on keeping the 11" rears then I think 235/305 is the way to go....but then a lowering is needed for the look to be better. 20" rears at 12" wide (or even 11.5) really solves a lot since you can run the 325/25.
Tomp
Mar 27, 2022 05:59 AM
horsepowerfarm
Sep 10, 2015 06:09 PM
I'mAllIn
Aug 25, 2015 09:44 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
