GT3RS rim fitment
Old Aug 25, 2014 | 05:07 PM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
GT3RS rim fitment
I have opportunity to buy a set of center lock 2010 GT3RS rims. Has anybody used them on their turbo. I have read about front differential problems when you go with the wider rims and tires, is this true.
Old Aug 25, 2014 | 05:13 PM
akunob's Avatar
akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !akunob Is a GOD !
There's some good info on the fit of the GT3RS wheel on turbos in this thread...hope it helps. GL with that wheel, it is HOT!
https://www.6speedonline.com/forums/...g-version.html
Old Aug 25, 2014 | 06:22 PM
90sundevil's Avatar
Thanks I saw that and another thread about the diff. Never found out if the wider rims and tires caused the diff failure or not.
Old Aug 25, 2014 | 07:29 PM
Mario911TS's Avatar
Mario911TS is just really niceMario911TS is just really niceMario911TS is just really niceMario911TS is just really nice
There are certain sizes you can use that will not damage anything.
I don't think a Wider wheel will have any problem, as long as you run the correct tire size.
For example, my car has 1'' wider rear wheel and 0.5'' Front, and I use stock measurement tires.
On wider wheels, some tires might look stretched, while others look OK.
My friend has HRE Wheels on his Turbo S, with 335 tire on the rear and I forgot the front, and that's fine too.
I think what you can't use is 325 or 315.
Old Aug 26, 2014 | 12:57 AM
WaltB's Avatar
WaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond reputeWaltB has a reputation beyond repute
You can run the GT3-RS wheels on the turbos. 19 inch, 245 fronts and 325 rears.
Walt
SM_ATL
Mar 26, 2016 03:02 PM
cgunsch
11
Nov 27, 2015 11:20 AM
brickdawg
Sep 11, 2015 09:08 PM
Wegentop
Sep 7, 2015 08:23 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
