07 Turbo -- 40k mile maintenance / upgrade list
Old Sep 16, 2014 | 09:36 PM
Lysoleverywhere's Avatar
Lysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really nice
Hi All,
I recently picked up my (new to me) 2007 Porsche 997.1 Turbo and I'm completely going through the car to make sure it's absolutely perfect.
Anything I should replace/upgrade while I'm going through it? I'm extremely meticulous about my cars, so while I'm in here rootin around I want to make sure I cover everything so I don't have to do anything for a while.
The car has 40,000 miles. Does this list look complete?
Thanks in advance!
Joe T.
Atlanta, GA
Due for replacement
- Oil Filter, o-ring, and crush washers
- Wiper Blade Set (not shown)
- Summer Windshield Wiper Fluid (not shown)
- Charcoal Pollen Filter
- Engine Air Filter
- Spark Plug Set
- Fuel Filter
- Engine Drive Belt
Recommended inspection:
- Diagnostic system - read out any faults in memory (Porsche Dealer)
- Inspect all under-body panels - ensure all are secure and tight
- Inspect coolant level and antifreeze
- Inspect radiators for blockage or external debris
- Inspect brake hoses and lines
- Inspect all drive shaft boots for leaks or wear
- Inspect tire condition and air pressure
- Check front firewall drains (rear drains on cabrios)
- Check the door, lid locks, and hood latches for proper function
- Check vehicle lighting and headlight functionality
- Check horn function
- Check windshield & headlight washer system & nozzles.
- Check battery condition and electrolyte level
- Check function of electrical equipment, including warning and turn signal lights
- Visual inspection of pads & rotors for signs of wear
Old Sep 17, 2014 | 09:21 AM
r_matt_6's Avatar
r_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud ofr_matt_6 has much to be proud of
Maybe do the ignition coils while you're in there.
Old Sep 17, 2014 | 09:27 AM
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
+1, I would definitely replace the coils while doing the plugs.
Also I would check the FPR line as well https://www.6speedonline.com/forums/...-fpr-line.html
Inspect the diverter valves
Maybe do a boost leak test for good measure
Old Sep 17, 2014 | 11:36 AM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
I plan to do the same thing in a few weeks..already have done the air filters and still need to do the plugs and coils and belt.
I've been collecting the tools I need for the spark plug job.
Your list looks pretty complete.
I need to look for a write up on doing boost leak checks..
Old Sep 17, 2014 | 03:46 PM
bgrpph's Avatar
bgrpph has a spectacular aura aboutbgrpph has a spectacular aura aboutbgrpph has a spectacular aura about
as said above, i'd also replace coil packs while doing plugs- also change
trans fluid & differential fluid & flush brake fluid
The_Ruski_Driver
Oct 25, 2015 08:40 PM
SharkyShark20
Sep 19, 2015 09:54 PM
Vrseis
Aug 20, 2015 07:41 AM
