LOCAL in the USA PDK Upgrades
Old Oct 16, 2014 | 09:41 AM
  #31
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Originally Posted by rix
That's funny. I wasn't endorsing them as a vendor, but more for what they (appeared) to have laid out on the table.
hehe that was laid out on our table, over 4 years ago in 2010.
Old Oct 16, 2014 | 09:47 AM
  #32
Originally Posted by Stage7
Have you picked up your .2 turbo yet? Did you go PDK?
A couple Deals fell thru but it's coming.
Old Oct 18, 2015 | 10:22 PM
  #33
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Has any body built a Pdk that holds 1000 whp
Old Oct 19, 2015 | 09:16 AM
  #34
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
BBi. You'll hit the fueling limit way before you hit the PDK limit.
Old Oct 20, 2015 | 06:13 PM
  #35
993Godspeed's Avatar
993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !993Godspeed Is a GOD !
Whats the issue with fueling? Isn't it as simple as replacing the part causing the issue? Injectors, rails, pump etc? Something tells me it's not as simple as it sounds.
Old Oct 20, 2015 | 06:34 PM
  #36
Thunder915's Avatar
Thunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond reputeThunder915 has a reputation beyond repute
Sound slow and complicated
Old Oct 21, 2015 | 06:24 AM
  #37
longboarder's Avatar
Agreed not simple at all. Discussed with BBI at length recently.
Anyone can upgrade the LPFP / HPFP and increase injector size.m etc. This has been tried years ago but the car will not run properly. It's the ECU. On the 997.2 and 991's, the ECU doesn't just control the motor. Or the trans. It controls essentially every aspect if the car. All at once. It's a brain. And it doesn't want anyone to f*ck with its fuel system. My guess is that someone very sophisticated needs to find the fueling codes buried deep in the millions or even billions of lines and reprogram it. This is not a task for a typical engine tuner. But rather an automotive software engineer with intimate knowledge of this particular ECU. Maybe even the guys that programmed it in the first place.
Old Oct 21, 2015 | 06:30 AM
  #38
Thunder915's Avatar
Originally Posted by longboarder
Agreed. Discussed with BBI recently.
Anyone can upgrade the LPFP / HPFP and increase injector size.m etc. This has been tried years ago but the car will not run properly. It's the ECU. On the 997.2 and 991's, the ECU doesn't just control he motor. Or the trans. It controls essentially every aspect if the car. All at once. It's a brain. And it doesn't want anyone to f*ck with its fuel system. My guess is that someone very sophisticated (like Porsche itself) needs to find the fueling codes buried deep in the millions or even billions of lines and reprogram it. This is not a task for a typical engine tuner. But rather an automotive software engineer with intimate knowledge of this particular ECU. Maybe even the guys that programmed it in the first place.
Aftermarket ECU could be the best solution IMO. I heard Syvecs work on it
Old Oct 21, 2015 | 09:13 AM
  #39
Gotcha. I think it's a matter of time. It will cost a penny probably but when this happens, oh boy. These things might run 8's.
Old Oct 21, 2015 | 11:04 AM
  #40
And it may be sooner than you think
8's? No chance except the middle east, but 9's on street tires here in the US, maybe
Old Oct 21, 2015 | 12:15 PM
  #41
Mit_Boost's Avatar
Mit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant futureMit_Boost has a brilliant future
Direct Injection is very new tech -- The low-pressure pumps can easily be be upgraded, but the high pressure pump is VERY difficult to modify. So even if you found a way to pump enough fuel for 2k HP on the low-pressure side, the high pressure would become a restriction if it can flow a max of 750 HP.
Then there's the injectors. As far as I know, NO Direct Injection engine has a injector upgrade.
SO, what everybody does (whether it's the TT-G's or R8's with the V10 FSI motor, or the BMW N54) is run a supplemental, port fuel injection setup from the intake manifold. Luckily, on the TT-G's/R8s, the standalone market has been able to get CAN integration, so the Audi/VWAG relationship will hopefully make CAN integration feasible on the Porsche market.
But then there's the PDK...
Old Oct 22, 2015 | 04:26 AM
  #42
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
Champion cars are already running 9.8s on street tires....drag radials are street tires
Old Oct 22, 2015 | 06:55 AM
  #43
Cause I just ordered some 18" centerlocks with MT ET Streets and I'm gonna drive to the track with them. Didn't really think about classifying them as street tires but alright then
Old Oct 22, 2015 | 01:58 PM
  #44
dvpouldar26's Avatar
dvpouldar26 is a splendid one to beholddvpouldar26 is a splendid one to beholddvpouldar26 is a splendid one to beholddvpouldar26 is a splendid one to beholddvpouldar26 is a splendid one to beholddvpouldar26 is a splendid one to beholddvpouldar26 is a splendid one to behold
Possibly something to consider what is done for the BMW N54, N55, and S55 DI cars... It would be interesting to see a plate port injection solution for the 9A1. Several companies have come up with port injection solutions for the BMW DI cars with an additional fuel rail and additional injectors under the oem intake manifold. I think BBI was looking into this. A LPFP upgrade will also needed.
In terms of software and controlling fueling, I know a standalone such as syvecs has been brought up. Why not try what is working for the BMW DI upgrade kits? They are using the Split Second Additional Injection Controller. This is what Burger Tuning and Motiv Motorsport are using for their port injection kits for the N54 and N55. It simply connects to the each of the port injectors and uses a tach signal to spray at the ignition rate. It can be further fine tuned using its own software. Seems like a much simpler and cost effective solution than a standalone.
Here's links for both example of the port injection kit and the additional injection controller below for the BMW N54... possibly something to look into or try out.
http://www.motivmotorsport.com/produ...or-controller/
http://www.motivmotorsport.com/produ...it-second-aic/
http://burgertuning.com/N54_secondar...ctors_BMW.html
Old Oct 22, 2015 | 02:05 PM
  #45
Originally Posted by dvpouldar26
Possibly something to consider what is done for the BMW N54, N55, and S55 DI cars... It would be interesting to see a plate port injection solution for the 9A1. Several companies have come up with port injection solutions for the BMW DI cars with an additional fuel rail and additional injectors under the oem intake manifold. I think BBI was looking into this. In addition to upgrading lines and the LPFP, this may be a nice fueling solution hardware wise.
In terms of software and controlling fueling, I know a standalone such as syvecs has been brought up. Why not try what is working for the BMI DI upgrade kits? They are using the Split Second Additional Injection Controller. This is what Burger Tuning and Motiv Motorsport are using for their port injection kits for the N54 and N55. It simply connects to the each of the port injectors and uses a tach signal to spray at the ignition rate. It can be further fine tuned using its own software. Seems like a much simpler and cost effective solution than a standalone.
Here's links for both example of the port injection kit and the additional injection controller below for the BMW N54. The link is for a 4 injection controller but 6 injector modules are available is well... possibly something to look into or try out.
What I'm referring to a solution however that keeps the stock ECU. I think running a standalone on this car would be an even larger issue because the factory ECU is so complex and as far as I know, no one has tried on a 997.2 ECU. But props if someone can figure it out.
