Good tuners in nj for a 997tt
the exhaust is a 3" out the turbo and thru the "short route", after it Ys off and the whole "long route" is 2.5" to keep the noise down and the drone away. X pipe on the porsche is the best sound you can get, problem is it causes back pressure on higher hp cars. ive tested this with tim on my 996. with this setup the short route will open up when you are really getting on it and you have performance and noise of straight pipes.
I'm not doubting it, just curious because GMG and BBI both use x pipes in there exhausts. I also agree it sounds great.
Nice that you have the best of both worlds.
not everyone wants to drive around with straight pipes full time. when you get to the bigger power levels sacrifices have to be made.
#TeamAIM
#TeamAIM
They both make great exhausts, but I'm pretty sure they both go straight pipe (or something close to the Proto non-merged "X" Pipe) for their higher HP builds. Example: BBi's King Kong for example has straight pipes.
I have a proto exhaust too. I believe they just cross over each other but don't actually merge. If you want to stay in nj your in good hands with Garth. Fab work is excellent
Feelgood MD
Mar 24, 2016 09:35 AM
