Interior door handle spring broke ?
Old Nov 15, 2014 | 05:12 PM
baziturbo's Avatar
baziturbo is infamous around these partsbaziturbo is infamous around these parts
Hi fellas.
After a drive today, I pulled my driver side interior door handle to get out and heard a weird noise like some spring broke and the handle is now loose. Door still opens by pulling on it but clearly the mechanism is not working right. Anybody experienced this and if so is there a link for a fix or is it dealer time ?
Thanks in advance!
Old Nov 15, 2014 | 05:19 PM
VIP C4's Avatar
VIP C4 is infamous around these parts
Typical problem. I had the same problem but fixed with a couple zip ties. Your spring probably did not snap, it's a plastic tab that broke. This apparently is a poor design by Porsche, this tab is so flimsy holding on to its dear life everytime you open you door. Anyways, all it takes its a few screws to take out the panel, once you have the panel out, you will see the mechanism that operates the locking system, it should be pretty clear where the spring sits, and that there should be a plastic tab to keep it in place. You can easily replace the tab with some zip tie to hold the end of the spring in place. Works like a champ
Old Nov 15, 2014 | 05:22 PM
VIP C4's Avatar
Heres a link for the panel removal. Step #10 shows the mechanism and the spring and you will probably see the broken plastic tab there. Good luck
https://www.6speedonline.com/forums/...moval-diy.html
Old Nov 15, 2014 | 05:39 PM
baziturbo's Avatar
Thanks!
Old Nov 15, 2014 | 06:47 PM
jessesick's Avatar
jessesick is infamous around these parts
I tried to fix ... Worked for little...ended up buying new part... Under $50 many places
Old Nov 15, 2014 | 10:49 PM
Lysoleverywhere's Avatar
Lysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really nice
Part #?
COBB Tuning
Jan 1, 2025 09:02 AM
nlakind
Nov 6, 2015 10:15 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 26, 2015 12:13 PM
TrackOne
Aug 20, 2015 12:56 PM
