Drain & fill engine coolant
Old Dec 2, 2014 | 07:59 PM
crgf1k's Avatar
crgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to allcrgf1k is a name known to all
Does anyone know an easy way to drain some coolant so I can add some fresh stuff without creating a large air pocket in the cooling system? I know this isn't ideal...a flush would be best, but I don't have time right now and it's extremely cold here (Ottawa Ontario). I'd like to drain out about 4 litres or so, pour in some new antifreeze, then drive it around for an hour or two to mix it up thoroughly. Thanks in advance!
Old Dec 2, 2014 | 11:26 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
I would use an antifreeze gauge to see what strenght your current coolant is. I believe it is lifetime coolant so depending on how cold it is, you may be in safe range.
Old Dec 2, 2014 | 11:46 PM
crgf1k's Avatar
Thanks for the response. I have a gauge and it reads low, it looks like it was diluted at some point so I need to drain some out and add some new stuff. I'll do a proper flush in the summer. I was just hoping to find out where most convenient drain point is before I crawl under the car.
Old Dec 2, 2014 | 11:56 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
As silly as this may sound, you may want to purchase a siphon for gas or oil, They sell these types of pumps at auto part stores, and replace what you extract with coolant. Probably the easiest way of replace your already mixed formula.
Just a thought, probably not the correct answer with the wealth of knowledge on this forum.
viprklr
May 23, 2018 11:33 AM
nlakind
Nov 6, 2015 10:15 AM
LiquidElephant
Aug 27, 2015 06:17 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
tscales
Aug 24, 2015 08:23 AM
