Porsche Tuning Tools
Old Jan 9, 2015 | 11:12 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
Originally Posted by nzskater
Can you expand on this statement? Keen to understand more.
For starters... I'm seeing a large movement of cars going 'Mafless'. In the MOST elementary terms the Bosch ME7 ecu is a load based system. Again in lay terms, load is calculated based on airflow. If your you remove the single most important sensor for load calculation you are inhibiting on the ecu's ability to do anything 100% correctly. Sure it "works" and i used "works" very loosely because the 997 has wide band fueling control and a good knock control system, but its far from correct. This could also affect subsystems that need proper load signals to function (think ABS, traction control and transmission controller)
Most will respond that "well, the car has a MAP sensor". If you hear this response form a a tuner about mafless tunes... Run, do not look back.
This is not just limited to the mafless cars. When eliminating vtg and going to a gt turbo we've seen cars pick up as much as 75hp at the same boost. Many changes like this require not just "map changes", they require "code changes" for the car to operate properly.
Its confusing but basically there's a big difference between tweaking and calibrating. There is far too much tweaking going on in this market at the moment. Tuners need full access to the ecu to tune these cars properly. In most cases (and in my opinion) commercially available tuning package do not provide the flexibility needed.
Old Jan 9, 2015 | 11:13 AM
Tony@epl's Avatar
Originally Posted by TimeTomorrow
Why did i not know you were local and had a reasonably priced reflash special price a few months ago.
Any advice for my current predicament? Every try the openflash? ProEFI daily drivability?
PM or Email me. Lets discuss further! We can help out.
COBB Tuning
Jan 1, 2025 09:02 AM
joseph_number1
Jul 19, 2018 05:45 PM
Oct 6, 2015 05:20 AM
Aug 20, 2015 12:17 PM
Aug 19, 2015 06:55 PM
