do the 997 turbos suffer from coolant line problems like the 996?
Old Feb 8, 2015 | 06:36 PM
GT32's Avatar
GT32 is a glorious beacon of lightGT32 is a glorious beacon of lightGT32 is a glorious beacon of lightGT32 is a glorious beacon of lightGT32 is a glorious beacon of lightGT32 is a glorious beacon of light
I thought I read that 2009 turbos did not have coolant pipe issue as Porsche had it rectified?
Old Feb 8, 2015 | 06:54 PM
bbywu's Avatar
All GT2s, GT3s, their variants, and Turbos pre DFI are subjected to a potential catastrophic coolant pipe fitting failure. So, yes, even the 2009s which uses GT1/M64 block are subject to this problem.
This leak, while not very common, is more likely to occur with age as the adhesive is subject to heating/cooling cycles. While the number of failures is small, a leak on the track can potentially lead to a catastrophe. Several have reported that their vehicles could not participate in track events because the tech inspectors would not allow an "un-repaired" vehicle on the track. The NHTSA did an investigation on the adhesive failure and decided that this problem did not warrant a mandatory recall. They completed their investigation about 18 months ago.
This leaves us with aftermarket welds, pins, or to thread the fittings a la GT3 RSR:
Old Feb 8, 2015 | 07:09 PM
bbywu's Avatar
Originally Posted by VGLNTE1
thanks guys. Stealership charged him 5400$ To fix the leak. Said it was from the housing? Not sure if that means the water pump, or a connection. Either way, I'm sure the dealer didn't pin or weld. :-/
Which means it will likely occur again some day.
Old Dec 27, 2018 | 06:45 AM
Fishey's Avatar
Fishey is a splendid one to beholdFishey is a splendid one to beholdFishey is a splendid one to beholdFishey is a splendid one to beholdFishey is a splendid one to beholdFishey is a splendid one to beholdFishey is a splendid one to behold
Where did you buy the RSR part? Also, there are 7 total fittings on a TT so that eliminates 3 which I am totally for threaded fittings just wondering the normal part number is 996.106.161 5R They simply thread the normal part and put on fittings?
COBB Tuning
Jan 1, 2025 09:02 AM
Aug 21, 2015 06:34 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
Vrseis
Aug 20, 2015 07:41 AM
PelicanParts.com
Aug 18, 2015 03:42 PM
