New Wheels - Question about TPMS
http://www.tpms.com/TPMS_s/4981.htm
What's wrong with these - 4 x $76.40 - seems to be priced right.
http://www.titantpms.com/tpms/porsch...uminum-9452427
I saw these too??? what do we know about them?
The titans are the ones I had issues with. I just had them swapped out for what is supposed to be the correct ones so I will see if they work next week. Do yourself a favor and call a dealer with your vin for the oem number. Then call whoever you are buying them from so you get a good match. Also my Indy said they could not program them with the piwis because they were not eom.
cheers
cheers
I just installed them 2 weeks ago
I heard that the ITM (after market TPMS, 433MHz) has issues for 997.1 Turbo. So it is best to use OEM ones. is it correct? As I need to change them fast and I don't want to buy the wrong ones.
The best thing you could do is call any dealer and give them your serial #. I know there is more than one type in the 433hz style. They will give you your oem part number (for cross reference) and then you can be sure you get the right ones from whoever you decide to buy them from.
Cheers
Cheers
I know the parts # from dealer. it is 99760602101. However, 2 ITM distributors told me that there are some issues with ITM TPMS to fit 2007~2009 997 Turbo, but no issue with 997.2????? is ti correct???? ITM price is really good comparing to OEM's. Can anyone inform me that the UPC# 9453585 (in the OEwheels site) will fit 2007 997.1 Turbo?
I mean if the ITM sensor will work on the 997.1 or not, as even OEwheel sales told me that ITM might not work..... but I heard people said they are fine... it is weird and I am very confused.
I used the titans and still have issues with them resetting all the time. I don't know about the ITM that you are referring to. How much cheaper than oem are they? If its not a substantial savings I would find a place that sells oem for a good price. I know oewheels had oem for a decent price.
Avoid the confusion and concern then...just pay extra and get the OEM sensors. As a % of what you paid for your car and what you'll pay for other maintenance, it's a small price.
Fist of all, my TPMS was not all that accurate - 3 to 5 pounds off, and as I have said before, I have 2 tire gauges and an air compressor. I check pressure regularly and don't believe I needed the TPMS so I had my indy disable it following the DIY posted in a previous thread by BBYWU.
