Techart Springs
Following alignment is used by a number of people here, essentially the alignment specs of the GT3, for street (not track). The main change is to increase front camber adjustment, hence increasing front wheel grip in corners, hence better cornering, less understeer, more sporty feel. First page of thread has basic discussion of basic principles
of suspension tuning: https://www.6speedonline.com/forums/...red-turbo.html
(no I am not a lawyer), this means increasing negative camber so the outside tires stay flat and remain in contact in high speed cornering. Don't know about 996, but for 997 with stock components, the max you could go is -1.2 in front, hence that recommendation.
No reason to think otherwise (it is possible for 997) but for 996 you probably want to post in 996 forum or check with your tuner to make sure.
First time I have heard of these. Unless there is some compelling reason to use them (is there?), my vote would be to use the tried and true: Techart, GMG, Eibach (all 3 rumored to be stiffer than stock), or H&R (rumored to be softer than the other 3).
Are there any other options? Is there maybe some sort of aftermarket/other application spring islotor that will raise the car ~10-15mm? I'm not excited about having to go back to stock.
A bit contrary to what I've always heard. H&R are stiffer and lower than Eibach. Be careful also adding sway bars, they will also make the ride stiffer. These days it seems like springs and the dsc suspension control system, along with an alignment, would be the best street alternative.
H&R spring is known to be softer than GMG and Techart, and likely even a touch softer than stock. This has been confirmed with actual measurement by a major and very capable vendor here - I don't mention it often because the measurement was never released for public viewing. Nevertheless, the "same as stock" character has been mentioned by a number of users. I tend to recommend the other 3 springs for this reason as I prefer stiffer springs (personal preference).
Sway bar is a crucial part of suspension tuning (understeer/oversteer behavior), I personally woudn't dismiss it. The sway bar has adjustable settings such that if you don't like the stiffness, you could go to the soft setting. It is true this is strictly personal preference, no right or wrong: if you want softness of stock, then stay with stock. OTOH, if you want to improve the handling, then IMHO it is a must. Because of the adjustability, in general I recommend it highly. Valuable learning tool/education too about handling for us enthusiasts.
Note that regarding the 3 mods you mentioned: lowering springs, DSC module, sway bars, I wouldn't pick any 2 and indicate it to be the "best" as this is again, a matter of opinion/personal preference. Keep in mind they act on TOTALLY different areas of suspension functions (springs, damper, anti-roll) so one can't say a is better than b. (Different, not better.) I got a little carried away
with this discussion, didn't I?
cannga,
You bring up the most important fact. Actual measurements of lowering comparing stock with the popular aftermarket springs. I am new to this forum as well as owning a Porsche 996 for only a year, but it seems like we all should not have to re-invent the wheel.
It is unfortunate, after a diligent search, I have come up empty on actual comparisons on lowering height, not mfg claims, but actual mods on cars with before and after spring installs.
I understand the sway bar adjustments can stiffen or dampen ride.
However, and don't laugh, I have no idea what "DSC" stands for, LOL.
I read it all the time, and have no clue!
cannga,
http://www.tpcracing.com/dsc.html
I agree. I can contribute my H&R figures. How should we measure? ground to top of wheel arches? ground to body directly in front of wheel?
do you know what the stock height was, I think most of the standard measuring techniques go to inside the highest point of the wheel opening, should get all four.
I will measure my stock height and report back.
ty
ty
