alignment
Old Apr 27, 2015 | 08:25 PM
speedsterr's Avatar
speedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud ofspeedsterr has much to be proud of
alignment
What is the best alignment for a TTS .2 that won't cause premature tire wire? Street driven car.
Old Apr 27, 2015 | 10:12 PM
speedsterr's Avatar
154 views and on one has opinions on what is the best alignment?
Old Apr 28, 2015 | 04:11 AM
handdoc's Avatar
handdoc is infamous around these parts
stock
Old Apr 28, 2015 | 10:00 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Hi Speedsterr,
Can you share where your tires are wearing? I would guess on the inside on the rears. I noticed the same situation on my stock setup. If you wanted less inner tire wear, choose a less negative chamber setup for the rear.
I believe that the stock setup is -1 on chamber with a -0.15 on the toe for the rear and -1 chamber and 0.0 for toe up front.
You will lose some handling characteristics with this type of setup.
For example, I run a - 2.5ish +0.15ish toe for the rear and a -3.3ish +0.02 toe for the front. This is aggressive but, car handles well and maintains even tire wear at the track.
With all of this being stated, It really depends on your driving style and your true intentions with your cars use..
Old Apr 29, 2015 | 06:26 AM
speedsterr's Avatar
Originally Posted by elite1
Hi Speedsterr,
I have stock alignment. I just wanted to have this car have better steering and handling similar to the newer cars. But I don't want to have increased tire wear. So I wanted to find out what is the spec I need to get better steering/handling, but no change to my tire wear.
Old Apr 29, 2015 | 09:01 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
This seems like a topic for Rennlist
Glasgo
Nov 30, 2015 02:37 PM
miken168
Oct 6, 2015 09:21 AM
Ronny-
Sep 30, 2015 07:30 PM
DSC Sport
American Muscle
Sep 23, 2015 10:51 AM
