What would cause low pressure while brake-boosting?
Old Jul 25, 2015 | 02:42 PM
nuclearfishin's Avatar
nuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the roughnuclearfishin is a jewel in the rough
I'm close to having my car back to where I think it should be as far as power. Data from the track last night shows I'm only off by a couple tenths. The only thing I still notice is that I don't get near the amount of boost I should while brake-boosting. Boost comes on strong and hard after the first 100-200 ft, but prior to that the car feels like it's gagging a bit. I've done this technique a lot with this car in the past and know that the boost used to build much stronger. Here are the things I've checked already: tightened hose clamps, new air filter, cleaned MAFs, new boost sensor. Any other ideas of what I should be looking for? Thanks!
Old Jul 25, 2015 | 10:58 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
Unless something changed Giac does't offer brake boosting.
Old Jul 26, 2015 | 08:10 AM
997.1 turbos have always been able to brake boost, nothing required from the GIAC tune. I've had the tune for a couple years and have never had problems brake boosting until recently. I can't seem to build enough boost prior to launch.
Old Jul 26, 2015 | 11:38 PM
twturbo's Avatar
Ok so you must have a tip right ? because i'm positive on a 6sp it's not an option it has to be tuned in & Giac doesn't offer it but Proto does & also Cobb & maybe some others,maybe someone else can chime in here.I know when i had my Proto tune i could do it & also now on my Cobb & it def gives you a sling shot effect when done on a roll.
Old Jul 27, 2015 | 12:04 AM
Yes, I should have clarified, it's a tip and I'm talking about brake boosting from a stop for maximum launch. It used to get around 8-10 psi however now it seems to only be getting around 4 psi during launch.
Old Jul 27, 2015 | 02:02 PM
Would logging data while brake boosting be of any value since this is where I suspect I'm not getting proper boost?
Old Jul 27, 2015 | 02:06 PM
ecpChris's Avatar
ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !ecpChris Is a GOD !
definitely would be a start
NC 996TT
Mar 23, 2023 06:19 AM
BLKMGK
May 31, 2016 04:32 AM
gpt817
Sep 8, 2015 10:21 AM
mjdVantage
Sep 5, 2015 07:22 PM
porsche42
Sep 4, 2015 08:21 AM
