Bluetooth Satellite Radio Options
Old Aug 3, 2015 | 12:50 PM
bmwtmx's Avatar
bmwtmx has a spectacular aura aboutbmwtmx has a spectacular aura about
Trying to find a good solution for Bluetooth and Satellite radio in my PCM with nav. equipped Turbo. I don't want to replace the entire stereo and do not want an obvious piggy back system. Open to ideas on what you did with pics.
Old Aug 4, 2015 | 06:03 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
You indicated you don't want to replace the stereo unit, and you also don't want to use a piggy back system..So not sure you have any other options? You would either have to replace the unit( Pioneer , Alpine, etc.), or add a piggy back device( Mobridge, Dension, etc.)...Unless I am misreading something??
DC
Old Aug 4, 2015 | 06:49 AM
bmwtmx's Avatar
Yeah I can see how this makes no sense! I don't want to replace the head unit as I want to keep the stock appearance. I was trying to see if there was a system that integrated into PCM on the backside. If not, I will do a piggyback system but I am not sure which work and how they look. I installed a Kenwood head unit on my 996TT with Bluetooth and satellite and the Bluetooth barely worked while the satellite was just ok. So trying to avoid that.
Old Aug 4, 2015 | 07:26 AM
Dennis C's Avatar
The only thing that doesn't look stock for the Mobridge installation is the mic for the Bluetooth phone. Mine is mounted on the windshield, close to the rear view mirror. It's almost invisible. I suppose that you could mount a mic in the OE location on the steering column, but I'm not sure. The Mobridge system lets you control songs through the OE head unit, and it displays track information on the PCM screen. It's a good solution.
Old Aug 4, 2015 | 09:27 AM
therock88's Avatar
Got it..The Mobridge and Dension units I mentioned do in fact integrate with the PCM MOST Fiber Optics and are likely the best two choices then.
There are other options that are FM Antenna modulators...not sure you would want that.
Good luck.
DC
Old Aug 4, 2015 | 09:37 AM
bmwtmx's Avatar
Think I will stick with either the Mobridge or Denison products. I need to research them out better but is there clearly one that is better or are they about the same?
Old Aug 4, 2015 | 12:56 PM
Cart13r's Avatar
Cart13r is a splendid one to beholdCart13r is a splendid one to beholdCart13r is a splendid one to beholdCart13r is a splendid one to beholdCart13r is a splendid one to beholdCart13r is a splendid one to beholdCart13r is a splendid one to beholdCart13r is a splendid one to behold
I have the Nav-TV (aka Tooki) kit and im quite happy with it, it was easy plug and play. Installed myself, took less then an hour.
Old Aug 4, 2015 | 12:58 PM
Sayajin's Avatar
Sayajin is just really niceSayajin is just really niceSayajin is just really niceSayajin is just really nice
I have the Mobridge in mine and you can't even tell its there. Integrates perfectly. My mic for the bluetooth phone is actually mounted in my gauge cluster right above the Tac and you can barely see that as well.
-Sayajin
Old Aug 4, 2015 | 09:14 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
Get the Tranzit blu system that everyone loves $150 keep your head unit & you can get Sirus for free online if you already have a subscription ,then just listen through your phone ,thats what i do.
https://www.6speedonline.com/forums/...anzit-blu.html
Old Aug 5, 2015 | 09:01 AM
bmwtmx's Avatar
Been reading this over. Looks very very interesting. My only concern are the people who are complaining that it doesn't sound that great. Is that typical?
Old Aug 5, 2015 | 08:29 PM
therock88's Avatar
The Tranzit Blu device is simply an FM Modulator as I indicated above....Thus it simply broadcasts a signal by modulating it at a certain frequency through the antenna cable (like a radio station). It would not have the same quality as a Fiber Optic solution all else equal.
DC
Old Aug 5, 2015 | 08:36 PM
Goldduster's Avatar
Goldduster is infamous around these parts
I have the Mobridge in mine and have had nothing but problems with it. Am currently replacing it with an Alpine W957. May not have the old fashioned look but it'll bring it into the modern age.
Old Aug 6, 2015 | 08:27 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
I have the Denison BT 500s and it works great. Need to follow the instructions to the T for a good outcome. Buy it from Eric at bumperplugs. Fantastic service and a wealth of knowledge. After the install, I has a few issues and Eric helped me out. Turned out to be the Samsung I was using.
Good luck with your choice.
Old Aug 6, 2015 | 11:17 AM
matt2ace's Avatar
matt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to allmatt2ace is a name known to all
I am using the Denison as well. Works great for Sirius/XM (use the Aux input for great sound) and digital music from an SD card. My Samsung S5 will not sync properly via bluetooth, but the system works with every other phone I have tried. The problem is with the Samsung phone, not the Denison.
cnebrask
Oct 3, 2024 08:19 PM
twnj
Apr 29, 2016 05:18 AM
SRC4S
Sep 1, 2015 09:22 AM
