704HP/691ft/lbs 997.1 Cabriolet
Old Oct 4, 2015 | 12:21 PM
roncooper's Avatar
roncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond reputeroncooper has a reputation beyond repute
I never dynoed the car on pump, we did however make 13-15 revisions of that map. The best 60-130 I got on pump was 7.2 I believe. With this being said there is something left to be desired about my ability to get the most out of the car.
I would be surprised if the car ran a 6.3. I'm at about 750 above sea level here.
I'll for sure post a verified vbox run once I do it. I have a hard time believing some of these times people report without providing the logs or verified graphs.
Old Oct 4, 2015 | 12:23 PM
roncooper's Avatar
Originally Posted by Bobbyfali
Pls get some 60-130 times, you have a sub 6sec car there!!
Is the car actually running 12.5A/R's?
What power did she put down on pump and do you have a dyno chart of that as well?
I'm not sure what the AFR is exactly, I haven't reviewed the logs myself nor have I driven the car since they dyno pull. The weather has been crappy here in central Ohio.
Old Oct 4, 2015 | 02:36 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
A couple of runs I just did 4th gear, so it takes out the "ability" factor and more consistency for measuring delta's before and after mods.
I know about the 60-130 #'s, but I use it under the same conditions to measure and it is almost flat and almost going a tad up hill. I don't care for bench racing 60-130 based on what your saying above, as when your door to door on the streets is how you tell who is faster in the real world.
Just do a 4th on a even road (repeat all test there) roll up to 45-50, mash the throttle, hold on until 7200rpm, repeat three times (after a mile or so cool down), take your average and bang! So when you do your next mod you can do the same test and see your delta difference.
If you do the above on a flat surface you should be 6.1's or better for sure with that power band you have and wouldn't be surprised if sub 6's rolled up.
When you did your pump gas 60-130, what method did you use?
Old Oct 4, 2015 | 02:58 PM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Originally Posted by A418t81
Graph looks great man! These are the Xona compressor wheel'd ones right?
Yes, Xona uses the HTZ compressor wheels.
Old Oct 5, 2015 | 07:54 AM
jjurroz's Avatar
jjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant futurejjurroz has a brilliant future
I'd be interested in the logs if they're available.
-Jose
The car runs 22.5 max psi.
I'll post some logs of pulls if people are interested.
I'm not sure why that video didn't work I'll see if I can get the original from the person shooting it
Mod list:
65mm VTG
AMS headers
Inlet pipes
Tubi Race
AMS intercoolers
AMS Y pipe
82mm throttle body
IPD plenum
1000cc injectors
Cobb Accessport E85 map MAFless
Clutch and lwfw
I also converted the car to centerlock wheels with Porsche RS Spyder wheels. While I had the engine out I pinned the coolant lines and replaced the oil cooler elbows.
All the work was done by myself and a friend in my garage.
Old Oct 6, 2015 | 08:35 AM
some solid numbers !
#TeamAIM
Old Oct 9, 2015 | 08:35 AM
roncooper's Avatar
Log
Here is the Log from the 704-691 dyno pull
Looks like my injector duty cycle was around 86% with the 1000cc injectors which I am very happy with.
I know I have/had a small boost leak on bank 1 at the intercooler. I need to re clamp the hose and I just haven't had the time to pull the intercooler to do so.
You can see the duty cycle on the turbo on that side is a little higher.
Looking at the 65mm VTG duty cycle you can see these guys are not nearly working as hard as they are capable. What would be interesting to see is how these 65mm HTZ wheels compare to the 68mm HTA wheels. I would surmise that the 65 mm are more efficient and would make as much power yet with less back pressure.
File Type: csv
Old Oct 9, 2015 | 11:11 AM
COBB Tuning's Avatar
COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !COBB Tuning Is a GOD !
Looking good Ron!!
-Mitch
Old Oct 9, 2015 | 02:48 PM
rix's Avatar
rix
The limit with either turbo is probably going to be in the turbine. You might get a little more with the 68mm over the 65mm though. The difference between 65 HTZ vs 68mmHTA would still favor the larger wheel based on the anecdotal evidence I've seen.
Old Oct 9, 2015 | 03:16 PM
roncooper's Avatar
Well Dan we almost figured that out. Anyone else have a 68mm dyno chart on e85?
Old Oct 9, 2015 | 04:03 PM
SamboTT@ByDesign's Avatar
You burning up some rubber out there?
Old Oct 9, 2015 | 04:11 PM
rix's Avatar
rix
I was about to get one but ran into some difficulties.
Old Oct 10, 2015 | 06:50 AM
The Bogg's Avatar
what is the rated flow capability of the 65htz? it's 47lb/min for the 68hta in the Champion turbo.
Old Oct 10, 2015 | 08:38 AM
IMI A's Avatar
IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !
Thumbs up
Guys the only way you are really going to know which turbo performs better i.e. 65mm or 68mm is to run both side by side on same day all the way up to VMAX. Until you do that this dyno info is v.interesting but not properly field tested
Intrigued to see the results myself.
Old Oct 10, 2015 | 10:28 AM
The 65HTZ flows at 44 lb/min and responds better being smaller. HTA are still better than most. Plenty of air I have found and a nice match. Lots of cars running strong with this set-up and room to go.
