Tire Ratios = problem ?
Old Oct 26, 2015 | 04:55 PM
TripleNet's Avatar
TripleNet has a spectacular aura aboutTripleNet has a spectacular aura about
Having some serious issues and hoping I am not screwed ....
Help !!!!!
Just installed a set of 20" Champion wheels with Nitto Invo's ..
245/30/20 front
305/25/20 rear
Also installed GMG springs ....
The car is dangerously unstable at speed ....
Mechanic thinks either the springs were installed wrong by previous wrench or the tire ratios are off ...
Just digging into this on the forums - but any help would be greatly appreciated ..
Thanks !!!!
Old Oct 26, 2015 | 05:11 PM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
Factory size is:
Front: 235/35-19
Rear: 305/30-19
With your current setup, you have a circumference difference (stock vs. new) of:
Front: -4.4"
Rear: +0.97"
So, you're current setup is a very different diameter compared to stock! This is pretty unhealthy for your differentials. Stock, the front circumference is ~80" and rear is 82". So, you can see that you are exceeding a 5% variance on the front...not much on the back.
You should be able to easily visually inspect the springs to see if they installed correctly or not.
Source: http://www.discounttiredirect.com/di...nfoTireMath.do
Old Oct 26, 2015 | 05:26 PM
TripleNet's Avatar
Originally Posted by TypeRx
Factory size is:
Front: 235/35-19
Rear: 305/30-19
Front: -4.4"
Rear: +0.97"
Thank you .... what about if the shocks were "loaded" incorrectly ?
I am a novice here so forgive me for the questions if they make no sense
Much appreciated
Old Oct 26, 2015 | 05:48 PM
Kricci's Avatar
Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !
agree with comment above -
if you are going to run a 245/30/20 you should run a 325/25/20 in the rear
You are playing dangerous game of roulette with your differential with those mismatched sizes.
Old Oct 26, 2015 | 05:51 PM
TripleNet's Avatar
going to put the stock wheels back on tomorrow and back to the tire shop to ***** a little .... or ***** a whole bunch
Luckily I only put on around 40 miles on the car ... Not driving it again until I get the stock wheels back on
Old Oct 26, 2015 | 06:23 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Easy thing to check without much knowledge. Put stock wheels/tires back on and drive it aggressively and see how stable it feels. If it feels solid and fine, then the shocks were likely done correctly and it is the tire mismatch. If it drives poorly with OEM Tire, the likely is the suspension set up.
Either way, get those tire ratios corrected so you do no blow up yoru all wheel drive differential.
Good luck!
DC
Franc01
Oct 13, 2015 01:13 PM
richard181
Oct 11, 2015 07:45 PM
WheelB
BMW //M
Oct 9, 2015 09:42 AM
Oct 5, 2015 12:51 PM
