Real life maintenance experiences
Hey everyone,
I think it would be helpful (to me and other future 997tt owners with the p-car bug) if current owners could kindly chime in with the following info. I want to see what the real world is experiencing, what is hearsay what is not, and would like to know what to expect wrt to maintenance. Thanks!
1a) MY of 997tt; year and mileage when bought 997
1b) Automatic or manual transmission?
2) Current mileage of 997
3) Repair issues if any, and cost related to issues
4) Any aftermarket warranty bought and price paid for the warranty
5) How long do you plan to keep your 997tt?
5) If you had to do it over again, would you have bought another 997tt?
I looked for 1 year before I found the right car for me... It is fully loaded be it's all the little details that I like the best.....you would think with 600hp I would drool over performance but piano black seat backs yellow stitching pccb..are the extras I like the most after I take car cover off....btw my car has 9200mls...2008 and just do my reg oil change every year..my warranty will be running out soon don't plan on extending ....
1. MY 2008; purchased July/2014 with 49,xxx miles (2nd owner)
2. Current mileage: 50,xxx
3. Rear tires ($700), vacuum leak and faulty oil pressure switch ($1,300)
4. No aftermarket warranty - now wondering if it was a good idea
5. Would do it all over again - sometimes I miss the high revving NA, but there's nothing like that slingshot feel from the turbos
Hey everyone,
1) 2007 bought with 62k
2) 63k
3) Great PPI and 60k maintenance done on my dime -- coolant pipe popped out (a surprise) so in the shop getting them all welded. Also am addressing the clutch slave weakness with the gt2 conversion.
4) no warranty
5) How long do you plan to keep your 997tt? Forever!
5) Yes I'd do it over again!
2) 63k
4) no warranty
My over 30 years of German and Italian car ownership has caused me to develop the following adage: Never own a post-OBDII European car without a warranty or service contract.
1) MY of 997tt; year and mileage when bought 997
Bought last year (2008) CPO WITH 14,000 miles
About 18,000 miles
Coolant leak (repaired locally with cash out of my pocket, I forget the price) added ECU upgrade and it was recommended to replace spark plugs (about $600 to replace)
I added a ECU upgrade (about $2,000) and Kline exhaust. Ilove the additional HP and it's a ROCKET and I feel like the king of the road. I now have a slight gear change hesitation between gears under hard acceleration but I am still happy with the ECU upgrade (it's a Tiptronic)
Was CPO so I'm sure I paid extra when I purchased the car
Not sure, I love the car and plan to keep it for a couple years, maybe more.
YES, the car is rock solid, has back seats (I came from a Porsche Cayman S), pretty
much the fastest thing on the road and handles great, love the looks, can add tons more HP if desired, great car! I live in a small town and don't get many racing challenges, I guess the turbo emblem scares them LOL.
Chris (Topher)
About 18,000 miles
Chris (Topher)
Had mine from new - breakdown of running costs here - not cheap as a dd:
http://www.pistonheads.com/members/s...sp?carId=56626
Bought my 997tt new. Have 20k miles on it.
Oil Change Every Year. 9 qts of My
Air Filter
Tires
For such a high performance porsche it's extremely LOW maintenance.
If I recall I had the O2 Sensors replaced in '09. And had my Short Shifter adjusted once. And 1 Set of Tires.
Air Filter
Tires
2007 997.1TT 115,000KM (60K put on by myself) No warranty
Maintenance:
Brakes
oil
spark plugs
Tire PSI senors
Battery
Coolant Pipes just in case
Cleaning of Mass Airflow because of BMC (Subsequently threw away BMC)
Clutch
Many tires
Issues:
Mysterious coolant leak in the winter that dissipated
Oil leak by filter housing
Blew non weldable coolent line
Blew driver side turbo
Replaced front drive shaft
Replaced front axles
Broke front diff
Replaced MAF's
Mods:
GT2 Intercoolers
No cat exhaust
H&R Spring
Denison (very problematic)
Cobb stage two flash
Maintenance:
Brakes
oil
spark plugs
Tire PSI senors
Battery
Clutch
Many tires
Issues:
Broke front diff
Replaced MAF's
Mods:
GT2 Intercoolers
No cat exhaust
H&R Spring
Last edited by mikestyle; Oct 28, 2015 at 02:25 PM. Reason: Updated for accurace (**** broke)
1) MY 2007; Bought a couple months ago with 37,000 miles.
2) Currently around 40,000 miles.
3) So far
- New Front Tires (~$700)
- New Battery ($200)
- Spark Plugs ($900)
- Door latch assembly replacement - window wouldn't roll down when door opened, I'm told this was the microswitch failure in the door latch. Supposedly quite common on these cars. ($400)
- Miscellaneous - Oil Filter change, Wheel alignment ($300)
4) Didn't have any original warranty left, and debated on whether to get aftermarket warranty. So far, with what I've had done, had I gotten the warranty, it would have probably only covered the Door latch replacement.
5) Loving it, Don't think I'd ever grow tired of that power. Will probably keep it till the day I die.
5) Hell yes! So far, any issues that have cropped up haven't been too out of the ordinary, so maintenance wise, I can live with it. *knock on wood*
3) So far
1) MY 2007, purchased with only 1800 miles on it in 2009. Car is 6 speed manual.
2) Current mileage: 9200 miles
3) Only had to replace tire pressure monitors sensors on all 4 wheels, $600. These sensors have batteries inside and last only 5 years...
4) Went with 6 year Fidelity Platinum Warranty, cost depends on mileage and year of car and whether it is still under warranty when buying extended warranty. I paid around $2500 back in 2011...Call Christine Takla at Circle Porsche and she will beat anyone out there (562) 597-3663 x1030.
5) Plan on keeping it for at least another 5 years. Car is a garage queen, flawless, Sunday driver. May consider Turbo S down road but not convinced of the PDK transmission. I like the third pedal...
5) Never regretted going from regular Carrera to Turbo...The Turbo acceleration and brute power is pretty amazing
<!-- / message -->
<!-- sig --> __________________
<!-- / message --> <!-- sig --> __________________
