Upgrading stock to 700+ HP
KILLER POST TOM YOU KNOW SFA
Tom, killer post, but we noticed some points that are incorrect.
Quote:
Originally Posted by Tom@Champion View Post
Since the factory GT2 turbo uses the same compressor housing and wheel as the standard VTG we'll focus on the turbine side, which is where the differences are. There are basically 3 differences between a stock GT2 VTG turbo and a stock VTG, all 3 are on the turbine side.
The standard compressor wheel is different on the 997.1 turbo, the GT2 wheel is larger. It is the same on the 997.2 but the compressor housing is different.
Info on wheel sizes and turbine material from the BW catalogue:
GT2 Borg Warner turbocharger specification:
BV50-2280DCB426.10BVAX0
997.1TT Borg Warner turbocharger specification:
BV50-2277DCB405.10BVAX0
997.2TT Borg Warner turbocharger specification:
The four numbers in RED indicate the compressor wheel size. All have the same size exducer, 56mm. The 997.1 inducer is 43mm and the GT2 and 997.2 inducer is 45mm.
The last letter that is bold and underlined indicates the turbine material. In this case O stands for Austenitic stainless steel, which is specially formulated to withstand high EGTs.
From the outside, the turbine housings look pretty much identical, but the GT2 turbine housing is actually made from a different material, to aid in cooling efficiency.
Actually, as I pointed out above, the housings are made of the same material according to Borg Warner spec.
Your cooling statement is inaccurate as well. Heat should be kept in the turbo, turbine housings are never cooled. That is why you see some people wrap their turbos or even coat them. You want to keep the energy inside the turbo and not dissipate it. Please don't confuse this with exhaust gas temperature...that is an entirely different conversation.
Notice the very small flat surface on each of the turbine blades. This is done to essentially slow the rotation of the turbine wheel and prevent it from spinning at a rate beyond the flow capacity of the compressor housing.
This is also technically not correct.
Rotational speed is controlled by the vanes, the blade profile is not a factor. Clipping the wheel is to decrease back pressure and therefore EGTs at steady state operation. This raises the flow limit of the turbine to better match the larger compressor wheel.
That's hybrid turbo 101, as in old Mitsu/Garrett hybrids and the like. Clip the turbine wheel for more flow and to control overall shaft rpm.
Also, you mention above "we noticed"... So who is we? The Royal we?
Uh, actually that IS correct. What do you think the net effect of lower back pressure is? The wheel spins slower as a result. Technically you're both right, but you're still wrong with the crappy attitude.
Just sayin...
nobody cares about a performance metric that can only be done in 1 place on earth. Standards and records are such because anyone can attempt them, be it 0-60, 1/8mi, 1/4mi, 1/2mi, 1mi, 60-130, 60-1500ft, 60-1600ft, and of course dynos of different makes.
claiming something when literally 99.999999999% have not and can not attempt is useless.
Hi Tom just a quick question.
How do you manage to create the claimed horse power of the 68mm from just changing the compressor side of the VTG turbos and not doing anything to the housing of hot side of the turbine?
Wouldn't that create a bottleneck and wouldn't the power be dictated by the smaller hot side not being able to keep up with the new sexy looking bigger cold side ?
Just curious as I am very interested in your turbos.
Also do you use the gen.1 hotside or do you upgrade yours to the slightly bigger GT2 RS hotside?
885 whp is marketing. You'd be disappointed upgrading from FVD 66mm hybrid VTG to another hybrid VTG solution IMO if more power is your goal. In fact if Tom guarantees you 885whp or your money back on your 3.8 FVD built motor (in fact forget that 750bhp at the crank on pump) take his hands off and lets run the car at Brunters. Happy New Year Buddy!
You'll be waiting along time for a response. There are people who have asked Tom this question in the past and no response almost 5 years later.
Happy New Year
I have also answered the question many times, but you will believe whatever you want to believe, so there's no point answering you any more. 9e is the best tuner ever, Champion Motorsport (company with a 20 year heritage of motorsport racing at the world's HIGHEST levels) are total liars, and every US tuner who has made this kind of power on VTG's are selling dreams. There....happy?
Happy New Year
Happy New Year
Ha ha 9e are the best tuner ever - I have never said or implied this previously? Look 9e or me do not sell in the US so have no axe to grind and 9e do not sell hardware full stop. When fitting my GT2 RS VTGS they bought them brand new from Porsche and then sent them to have hybrid billet wheels. motorsport bearings etc. I do not even send my car to 9e for servicing however yes I do trust the owner Ken and his staff implicitly and to be fair to them before I run them into the ground lol they have just won best tuner of the year award in the UK during 2015 and have won a few other tuning awards. Whether they are the best tuner in the UK or not or not makes no difference to me whatsoever and I realise you're pulling my chain.
Equally if I was in the US I'd happily consider Champion, BBi, Protomotive, Evolution, Markski, TPC, AWE etc etc etc and the only issue I've had with you Tom (not Champion) is your quite ridiculous 68mm VTG power claim of 885whp. With the greatest respect it actually shows you do not understand VTGS or their limitations. If you did understand VTGS you'd know how ridiculous your 885whp claim really is my friend.
Also I wouldn't be surprised if Champion 68mm VTGS (with GT2 hotsides) are perhaps the best hybrid VTGS but why try and make monkeys out of enthusiasts like me and the OP by claiming there are no issues with monster VTGS at high speeds and that you/GIAC have miraculous fairy dust to tune around EGT issues when running high levels of boost without datalogs and without any empirical data whatsoever? Its not good form in my view and its
how a few forum members here who obviously have 68mm VTGs get all defensive saying they know everything already etc etc.I had my 997 turbo from new 2007 but there are loads of new guys coming on to the 997 turbo platform like the OP from other marques who want to optimise their cars. The only reason I bother to post is,
A) these new guys like the OP have asked a perfectly reasonable question and deserve an honest answer,
and;
B) so they do not have as hard time as I did when choosing a tune or VTG turbo upgrade solution or at least they go into tuning eyes wide open.
Another very nice forum member Bogg who actually has Champion 68mm VTGS with 997 turbo hotsides knows they pull timing if running high boost at higher speeds on track and as he does not go above 140mph he is happy
But on the other side of the coin another Champion customer on the 60-130mph thread or 68mm GT2 VTG build thread (I can't remember) experienced in his own words at above 150mph " .... if the temperature gets too high the car lowers the boost automatically. The car will start spraying more fuel to cool. Which will slow down your car.
If you check the afr on your car when you are testing your car you might see it.
Thats the problem about vtgs at very high speeds."
The same guy set the awesome record 5.5 sec 60-130mph with 68mm Champion VTG set up in and then swapped his Champion 68mm VTGS as well as all the other Champion accessories like carbon inlet pipes, carbon airbox i.e. circa $20,000 + tune $ + fitting $ i.e. bolt on components out for GT 3076 turbos literally a few months later. This guy took a meaningful $ loss. If someone had maybe told him in advance the limitations of VTGS for his type of use or to spec GT2 hotsides rather than 997 hotsides and not to run high boost on runs above 150 mph he may still have stuck to a VTG solution albeit GT2 hotsides or gone straight for Garretts and saved a load of $ who knows.
If you dig around certain owners of 68mm Champion VTGs are quite open that they suffer pulling ignition above 140mph- 150mph. Hopefully
you can see why I struggle with YOUR 885 whp claim. You've not even run one of these cars in anger over say a mile so come on buddy give it a rest until you do. If you run the 885whp car over a mile and all the track data i.e. VBOX with datalog shows you do have 885whp I will be the first to congratulate you and I'd even consider shipping my engine to you to be built to the same spec. Have a prosperous 2016
lowpue
Nov 16, 2015 03:24 PM
hoeferland
Nov 10, 2015 05:42 PM
