e85 and hose between fuel rail
Old Nov 30, 2015 | 01:38 PM
SSMugen's Avatar
SSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond reputeSSMugen has a reputation beyond repute
*** Oops posted this in the wrong forum **** please delete.
Hi All,
Anyone know if the hose between the fuel rails need to be changed out when running E85? I'm only changing the pump setup (silly rabbit) and running new lines all the way back to the driver side fuel rail and then everything else is stock all the way back to the tank.
My question is do you need to change out any other hoses fittings along the way? I would figure you would but haven't heard I needed to do it.
Thanks in advance.
David
Old Dec 1, 2015 | 05:06 AM
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
Hi All,
Thanks in advance.
David
Only thing that needs to be upgraded is the injectors, pumps and hoses stays stock. Unless you are on non-vtg large turbos, but stock or upgraded vtg's seems fine with only injectors.
Old Dec 2, 2015 | 11:20 AM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
I looked at that hose too, I didn't see any reason to change it unless you were going to larger fuel rails, feed line, etc.
Old Dec 2, 2015 | 05:34 PM
32krazy!'s Avatar
this is a 996 turbo car guys. he posted in the wrong forum by mistake.
forbes210
Dec 2, 2015 06:32 PM
YellowmanTT
Nov 29, 2015 08:09 PM
Payton34ferrari
Other British Cars
Nov 29, 2015 07:54 PM
dhahlen
Nov 29, 2015 04:14 PM
