Tire questions (street vs track)
Old Dec 7, 2015 | 10:51 AM
Raider89's Avatar
Raider89 is infamous around these parts
It seems like common tire choices surround Pirelli P-Zero, Bridgestone Potenza, and Michelin Pilot Super Sport for my 997.1 turbo. When I got my car back in Feb, it had Bridgestone on them, needed new fronts, so stuck with Bridgestone to keep set same. This is garage kept, low mileage pleasure occasional weekend driver that am using for more aggressive stuff now. Have had 1 track day so far and intend to do 2-3 per year. This prompts a few questions and am curious if there is consensus.
-what is best tire for normal driving?
-what is best tire for road course?
-what about top speed at TexasMile?
-do we need to maintain set or mix match brands?
-do these tires require normal spin balance or road force balance?
Old Dec 7, 2015 | 11:03 AM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
If your road miles are limited and you're not spending too much time in the rain, I'd suggest Michelin Pilot Sport Cup 2's. Sticky enough to be more focused on your DE days.
That said, MPSS stand up reasonably well to fun use, and with only 2-3 events per year you'd easily get two years out of them. Mine have seen 6 track days and 11,000 miles total in the last 18 months, and they should last another couple of track days/months. They've definitely heat cycled a few too many times and they go off pretty quickly now, but not enough to discard them. I have a set of MPSC2 ready to go on for the summer.
Old Dec 7, 2015 | 12:28 PM
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
It's almost better to use 2 of wheels ,because the track & airstrip tires that work best like the Mpsc on track & Toyo 888 on airstrips will wear out very quickly with regular street driving ,I've heard as little as 2000 miles for some of the R compound tires.
Old Dec 7, 2015 | 04:05 PM
longboarder's Avatar
Normal street driving - Michelin PSS is terrific. Quiet, great cold grip, good warm grip, terrific in the rain too.
Track/Drag/Airstrip - if you are looking for one tire to do it all, then nothing can touch the R888.
Old Dec 8, 2015 | 10:15 AM
E-Gear's Avatar
E-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond reputeE-Gear has a reputation beyond repute
I agree with above.
One note: I had the Toyos on my Gallardo and they were indeed grippy, but noisy as they aged and they do age fast! Also, they do not give you the best lateral handling due to softer tire wall compared to the MPSS or stock BS tires.
Hope this helps
Thanks,
E-Gear
Old Dec 8, 2015 | 11:38 AM
kwiksilver's Avatar
kwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond reputekwiksilver has a reputation beyond repute
I recommend two sets of wheels. One for the track - 18" are probably best - and one set for street. A good set of tires for the track possibly R888. Tires for the street - Michelin probably best, but don't overlook Hankook which is an excellent street tire at a great price point. I would avoid Pirelli. I've been disappointed in Pirelli more than once.
Old Dec 8, 2015 | 04:41 PM
Yogi911's Avatar
Yogi911 has a spectacular aura aboutYogi911 has a spectacular aura about
Originally Posted by Raider89
-what is best tire for normal driving? -do we need to maintain set or mix match brands??
MPSS are a great all around tire, especially for the street.
Next i would get Bridge or Hankooks
Dont mix and match tires if you are going to do track and mile events. I wouldnt do it in the 911tt at all due to the AWD.
Will the car physically drive? Yes
Will you notice? Maybe, maybe not.
Would i do it? No
I have done it in the past on other cars...sometimes out of necessity sometimes because RWD cars like DR or wear out rears fast. But i wouldnt on the 911.
If your fronts are still good just buy one more set of rears and then you will prolly need all 4 or replace all 4 and keep the front 2 you have now as spares. Or just sell them.
Old Dec 8, 2015 | 08:22 PM
Code Red's Avatar
Code Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to beholdCode Red is a splendid one to behold
MPSC2 wear surprising well on the street...what a great tire.
Old Dec 8, 2015 | 09:56 PM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
If you think R888s are good I would suggest NT-01s a much better tire that will grip until they cord
Old Dec 9, 2015 | 11:21 AM
Raider89's Avatar
Kwiksilver; why are 18" better for track compared to stock 19" wheels?
Old Dec 9, 2015 | 12:29 PM
kwiksilver's Avatar
1. better selection of R compound tires
2. wider tire sidewall for smoother ride/ somewhat better handling
3. lighter weight/ less unsprung weight
4. less costly
There have been some debates over 18" vs 19" for the track. If you do a google search on the subject you can see all of the pros and cons, but if you are near a track check out what the race cars are running. Most prefer 17" or 18"
Old Dec 10, 2015 | 01:58 AM
IMI A's Avatar
IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !IMI A Is a GOD !
Thumbs up
For your use I'd also go with Michelin Pilot Sport Cup 2. Its a fantastic tyre from experience on both road and track. Best all round tyre out there at the moment IMO.
Old Dec 10, 2015 | 12:33 PM
cjcam930's Avatar
cjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond reputecjcam930 has a reputation beyond repute
MPSS is my fave street tire right now but has been unavailable in our sizes for around a year, unless that changed recently. FWIW I will most likely go to the MPSC2 next time I need rubber.
Old Dec 10, 2015 | 04:05 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
I do believe things are better now. I just bought a set of rears for my 997.2 TT from Tire Rack.
Old Dec 10, 2015 | 04:27 PM
Kricci's Avatar
Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !
Would you all recommend to run the Toyo R888's to the track or would you say to swap at the track if you are gonna run that tire?
I use MPSS on my 20" street set-up and i am very happy with them.
I recently put some MPSS on my track wheels because i don't trailer the car to the track and was worried that the R888's would wear out super quick driving on the highway to the events. I figured that the MPSS would be fine for awhile until i can see how often i will be tracking the car.
Curious what y'alls opinion is on that
