Need to find ground
Old Dec 8, 2015 | 09:03 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Need to find ground
Hi there. I am having a difficult time finding ground in the passenger footwell. There is a thread end of a bolt sticking out from the rear of the firewall. But I can't tell if it would be ground.
How can I test use a voltmeter?
Old Dec 8, 2015 | 10:52 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Photos are worth a few words.
Frame is ground. DC won't fry without ground. If a volt meter is secondary, a simple spark will answer your question.
If you use a voltmeter, turn the meter to DC and find a power point with the red lead . Contact the black lead with the possible ground and if your connection is correct, you'll get around 12 volt with the car off.
Old Dec 11, 2015 | 08:16 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
^^ what he said and if also run a resistance check between the bolt and the negative terminal of the battery - if the resistance is Zero or close to it, you have a great ground. This is good to do especially if you are connecting a radio, antenna or anything that can interfere with the entertainment system.
Old Dec 11, 2015 | 08:48 PM
Jako's Avatar
Thanks guys. Found great ground. Unfortunately the DSC is still interfering with something in the car and still creating an " eeeee" sound
Old Dec 12, 2015 | 12:28 AM
tomb18's Avatar
tomb18 is a jewel in the roughtomb18 is a jewel in the roughtomb18 is a jewel in the rough
Well, your so called great ground is obviously not so great if attaching the DSC system is causing noise to get into your audio. This is typically caused by "ground loops" where there is a current flowing through the ground circuit due to the ground not being really at ground. Your best bet is to run the ground directly to the battery with high enough gauge wire so that there is low resistance.
You may also want to talk to the DSC manufacturer about this. It could also be poorly designed electronics that have bad grounding or filtering of their circuits.
Old Dec 12, 2015 | 12:37 AM
Jako's Avatar
Thanks I have grounded the EMF wrap to the chassis. Measured with the multimeter, it zeros out. The only other system that I have is the dension and that is tapped into the footwell lighter socket. There is no other aftermarket device, I have installed in the car. Plus, I don't think it is coming through the audio. Reason, it is intermittent. Once the car is at rest, the sound will stop after a few seconds and will reappear once the car starts to move again.
This is now all pointing to The TPS DSC module. Others have had the same problem with no other electrical mods to their cars.
whoadude
Dec 11, 2015 10:17 AM
Staff@WORLD
Dec 9, 2015 10:16 AM
Erik@RSC
Dec 8, 2015 03:46 PM
