GIAC Solves 997.2 Fuel System
As long as it moves enough fuel (which it sounds like), no reason why not. Plus the DFI motor will love the cooler burn of ethanol.
Not just yet. But that is in the future. Part of the reason I think they picked my car is because I run meth and they (GIAC) can get to a point with no timing correction on race gas plus meth without introducing the limitation of e85 of a 30% greater fuel requirement.
I think e85 blends will better on the 991 since it already has a much larger capacity fuel system to begin with than the 997.2. By also adding the GIAC fuel system on the 991 running an e85 blend (maybe e40 to e50) will still allow for headroom in the fueling system with no timing correction. Not sure there will be headroom in the 997.2 on e50 even with the fuel system upgrade but that's for GIAC to figure out.
I have offered to donate my 991 if GIAC wants to do e85 testing next. $2 a gallon blended with 91 octane is so much more palatable than $20 a gallon MS109.
Can you explain why you are thinking this please. I re-read my posts. Nothing contradicting here.
Rob Harper of RobTuned, It was done quite some time ago. This isn't anything recent.
More info is here -> http://www.cobbtuning.com/porsche-99...g-rod-testing/
PORSCHE EXPERT GROUP - TIM BAILEY | JARED BRONSON | GRANT EPHROSS | ANDREW SCHWARZKOPF | HJ LEE
COBBTUNING.COM | LIKE US ON FACEBOOK | SEARCH KNOWLEDGE BASE | CONTACT US
unless you can run an e85 analyzer your going to hate the requirements for running e85. calculations how much fuel is in the tank, determining how much ethanol is actually coming out of the pump by testing, adding whatever you have to the full mix and pray it comes out right. run maybe 120 miles per tank and do it all over again. my buddy does this on his bmws its a major pia!
And to make sure the ECU is happy with the fuel one need to log, and this is where Cobb shines, just press a button, no need for a Duramteric cable and a laptop.
I ran E85 blends for at least 2years on my BMW (N54 DI), it was really simple, just fill 50% E85 and 50% 94oct it is close to E40. Sure topping up the tank to full wasn't easy but adding 20l of one fuel and then 20l of the other at the pump didn't require calculations, measurements or logging. Super simple....
i have seen e50 and e98 come out of the same pump at a single gas station. its wildly inaccurate and the regulations on ethanol content seem very lax. its available everywhere by me and the content is very unpredictable. fill it with e50 make a huge pull and you could blow the engine on a e85 file. just saying...
Not sure what the hang up here. It's already solved. It was solved using another 997.2 owned by a GIAC retailer. The system works perfectly. That car is now getting a built motor and PDK as we speak to take full advantage of the additional fueling. In the mean time, my car is at GIAC getting the system installed and going for dyno tuning. So it will be the first car with a working system although I won't be anywhere near the new fueling limit because I have stock motor, PDK and turbos.
