Help: EVOMS Intercooler install/DIY guide
Old Mar 20, 2016 | 06:09 AM
chrismc9's Avatar
chrismc9 is infamous around these parts
The EVOMS clubsport intercoolers require that your trim the upper and lower ducts on the intercoolers for a proper fit. Can anyone provide insight or pictures to which sections of the upper and lower ducts to trim?
Old Mar 20, 2016 | 06:14 AM
ctony66's Avatar
ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !ctony66 Is a GOD !
Old Mar 20, 2016 | 08:30 AM
Kricci's Avatar
Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !
The Rock's DIY's are always top notch.
As an FYI should look like this once installed.
Old Mar 26, 2016 | 10:03 AM
chrismc9's Avatar
Thanks for the supporting documents.
With the EVOMS clubsport intercoolers you will need to remove the inner lip on all 4 sides of each upper and lower duct (razor blade worked for me). I was also able to reuse the factory locking tabs on the sides (no need for cutting and using zip ties) of the upper and lower ducts. I would recommend using trigger clamps to hold the intercooler and ducts in place and apply even pressure to compress factory locking tabs back on the upper and lower intercooler ducts.
02black330ci
Mar 18, 2016 01:23 AM
vshugo996
Mar 16, 2016 08:40 AM
PelicanParts.com
Mar 15, 2016 04:08 PM
