997 TT cranking issue
Old Apr 25, 2016 | 07:26 AM
vr6tee's Avatar
vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !vr6tee Is a GOD !
I'm looking for help trouble shooting an issue.
I just had an engine out on a buddies 997 TT. After putting everything back together, I have an issue I've never experienced before. I went to start the car and everything powers up, but the engine won't crank over. I connected the Cobb accessport and it says "cannot connect to ECU". Now, if I remove the negative terminal on the battery for 10 seconds and re-connect it, the ECU is seen and the car will crank and start normal (but only 1 time). As soon as you turn the key to the off position, it loses connection to the ECU and the engine won't crank until you remove the battery again.
I've by-passed the clutch switch to rule that out. It seems like a ground issue, but the engine ground and battery ground are clean and solid. I was planning on removing/re-installing the starter wires to make sure they have a solid connection.
Is there a "breaker" fuse or relay that could be getting reset with removing the battery? Has anyone experienced this before?
Old Apr 25, 2016 | 04:59 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
It does sound like the issue is on the ECU itself.. What is the current stage on the ECU?
magoochi
May 11, 2018 02:43 AM
COBB Tuning
Oct 8, 2016 07:32 PM
Fadi
May 15, 2016 11:24 PM
changster
Apr 1, 2016 09:19 AM
SPEC V
NY Tri State
Mar 29, 2016 05:40 PM
