Oil Leak
Old Apr 28, 2016 | 01:58 PM
Mark's997T's Avatar
Mark's997T is infamous around these partsMark's997T is infamous around these parts
Oil Leak
I noticed some oil on my driveway recently and discovered the following picture.
Do you think this is a bolt issue or something else? I noticed this started happening when the weather got warmer.
Old Apr 28, 2016 | 03:16 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
That is the oil tank. I would clean it off. Hopefully you just need a new crush washer. Lots of oil is going to come out very fast once you remove the drain plug. Worst case could be someone creased the tank when tightening or loosening the drain. Thus causing a split in the tank.
Old Apr 28, 2016 | 08:43 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
As mentioned that is the oil tank. It appears that the oil is also above the drain plug, so may be leaking from up top on the oil tank..That happens to some of these cars. You can clean it up and watch to see if it is only at the plug, or coming from above...
Good luck,
DC
Old Apr 29, 2016 | 07:58 AM
Mark's997T's Avatar
Thanks for the advice. Will clean off this weekend and check it out. I had my oil change back in February so I would have seen something by now. It really started when we had drastic changes in temperature lately (80 degrees one day and then 35 the next). I'm wondering if the expansion/contraction of the bolt/washer metal is the root cause.
Old May 3, 2016 | 11:46 AM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
the leak is dripping down....so I do not believe it to be related to the bolt. I would look for leaks originating from the highlighted sections
Old May 3, 2016 | 11:53 AM
turboslut's Avatar
See pic
Old May 3, 2016 | 12:38 PM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
Man that's tuff to get to. Engine drop maybe?
Old May 3, 2016 | 01:04 PM
function12's Avatar
Might be a cracked oil filer neck then. #6 in the diagram.
evilruss
Feb 15, 2023 09:15 AM
away
Apr 28, 2016 10:48 AM
turbofever
Apr 27, 2016 10:37 PM
the_vetman
Apr 25, 2016 09:07 PM
evilruss
991 Turbo Vendor Classifieds
Apr 21, 2016 07:58 PM
