rattling sound from door when window is down
Old May 16, 2016 | 08:19 AM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
I have a rattling sound that I just noticed for the first time this weekend.
When the windows are down it sounds like a small piece of metal hitting another piece of metal.
Anyone else? 2011 TTS cab.
Old May 16, 2016 | 08:50 AM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
On something like this you don't want to take a chance. I would pop off the cover and see what is happening in there. It could be something coming loose - you don't want to wait until it completely comes loose and not being able to operate the window or getting jammed in there.
Old May 16, 2016 | 09:00 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Has a similar experience with my M3. The rattling also happened when the door closed. Brought it in to a shop and found out the power cable fell off its track and was touching the window
Old May 16, 2016 | 12:22 PM
JSF721's Avatar
Thanks guys, I had it out for the first time this season, took it for an inspection. I did not notice it until I was on my way home. The car was in my sight the whole time and I cannot imagine what could havce caused it.
Old May 17, 2016 | 09:28 AM
NoJoke's Avatar
NoJoke is infamous around these parts
I had the same problem.... Sure it's not the door latch (grease it up). There is more flex when the top and windows are down.
Old May 17, 2016 | 12:28 PM
JSF721's Avatar
Sorry, not following you, can you explain the issue and fix.
thanks very much
Jeff
Old May 17, 2016 | 12:59 PM
NoJoke's Avatar
thanks very much
Jeff
I was having a metal on metal tinging noise while driving with the top and window down and discovered it was the latch. By latch I mean where the door attaches to the frame when closing. If that is not it, then most likely the window regulator.
15PGTS
May 26, 2016 04:27 AM
minming
May 20, 2016 03:24 AM
trader247
May 16, 2016 12:14 AM
977ttblue
May 13, 2016 07:39 PM
