997.1 Oil Change/Maintenance Schedule...?
Old Jun 4, 2016 | 03:21 PM
Rez90's Avatar
Rez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond reputeRez90 has a reputation beyond repute
just curious what the schedule is like with these cars. I'm picking up my 997.1 on Monday and it had it's last service at 30k. It will have about 35k on it when i get it home.
How often does the oil get changed on these cars? and what are the other big things that need to be done and when?
Thanks in advance.
Old Jun 4, 2016 | 05:21 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
I always like changing the oil when I get a used car so I have a baseline and know what oil is in there.
As for oil, I would do every 5k miles or 12 months , whichever comes first
Old Jun 6, 2016 | 07:41 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Same here. Every 5k on gasoline, and every 3k on E85.
Old Jun 6, 2016 | 08:50 AM
Quadcammer's Avatar
Quadcammer is infamous around these parts
5k or once a year
Old Jun 6, 2016 | 09:00 AM
Rez90's Avatar
thanks guys. I also am curious on the other big items....tranny fluid...plugs...diffs....etc
Any other big things to write down?
Old Jun 6, 2016 | 12:40 PM
MK23's Avatar
MK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud of
Just to give a slightly different response: I do 7500 miles or one year whichever comes first. The manual says 10K but that seems excessive (although I seem to recall reading a thread where a forum member tested the oil in a lab after 10K miles and it was fine). My car is stock in terms of tune and no track days so maybe those things make a difference.
Old Jun 6, 2016 | 09:42 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
At 35k you are are just shy of coil and plug maintenance. Oils should always be changed on a used car. I did engine, rear diff, center diff and manual transmission on mine. The aforementioned was all done at the dealer.
I changed out the fuel filter and air filter as my first DIY items.
halb
Aug 16, 2017 09:04 PM
magoochi
Jun 12, 2016 09:07 AM
mpevo8
Apr 16, 2016 09:25 PM
solrac6262
Apr 13, 2016 08:22 PM
