Whipple noise (DVs?) after tune
... No one seems concerned with mine (dealers or specialists) however i would be interested if you do find out whats causing it
Hey Lennon, I had a simular issue. Did you have your windows down during the recording of the video?
https://www.6speedonline.com/forums/...hts-point.html
I posted a noise vid on the second page. Drove me nuts! Replaced clutch and various other parts including diverter valves (that ended up locking with an open position.) Literally spent two month problem solving an issue that i still cant explain.
I ended up losing 3K on my prior tune and spending $2k on a new one all fixed! Not bad for spending 5K. You may want to try before you buy and see if this is the same case for you.
nope, filter was on prior to tune, i think move would be to load stock maps back on evaluate, speak with softronics and then make a move from there.
Yeah I bet on the stock map you will hear it go down by 50%. You are hearing more air pressure divert through there. And the sport filter masks this less from the airbox side which can be heard from inside a bit. Just trying to help your worries about it.
joetwint
Apr 7, 2016 06:13 PM
WheelB
BMW //M
Mar 30, 2016 03:28 PM
