Iridium plugs...does anyone run them?
Old Sep 30, 2016 | 01:26 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Old Oct 1, 2016 | 03:09 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
I run Denso iridium 8s
Old Oct 1, 2016 | 11:57 PM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
NGK R7433-8 or -9 depending on desired heat range.
Old Oct 2, 2016 | 03:40 AM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Yes.....Denso IK22 (cooler due to tune and mods) gapped at .025
DC
Old Oct 3, 2016 | 02:47 PM
turboslut's Avatar
Does E85 tuning require a specific heat range? I am about 5k miles away from a plug change. So I want to be proactive about what I replace the plugs with.
I plan on tuning for E85 ultimately with upgraded vtg turbos, ICs and the 1300cc injectors.
How did you guys decide on plug and gap?
Old Oct 3, 2016 | 02:52 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
DC
Ran that same set up on all my turbos as described above. I ran them in my 911 as well up until I tried some plugs that required no gapping etc that prodigymb recommended.
I might switch back to the Denso's next plug swap to see as I really liked them...pending if I an not feeling lazy as the ones I am running have been trouble free as well.
