Emission Troubles
Old Feb 14, 2017 | 11:30 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Did the 4 step (impossible process) twice as close as I could.
Every field is good except the Secondary and vent. I now am starting the car every morning until the Secondary pump turns off (1.3+mins.)
I know the pump is working as the engine drops in idle RPM from 1,100rpm to 600rpm.
I'll give it a week with this process. If no change, i'll drop it off at the dealership for a few weeks for them to correct.
Old Feb 15, 2017 | 08:54 AM
Webspoke's Avatar
Webspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond reputeWebspoke has a reputation beyond repute
Originally Posted by elite1
Doobee really? I hate to hear that. I'm delaying my normal DIY winter maintenance trying to get this car to pass emissions.
Can anyone else relate to this issue with a Cobb flash?
I should have my gas cap tomorrow but, I wont be able to test it until Sunday.
I had posted earlier, I had to use a Cobb OTS flash modified for the 1000cc injectors. With that and a stock exhaust, I was able to clear all the monitors except 1 (enough to pass in texas) within 3 drive cycles. My secondary air pump has always cycled, even with the race tunes, on cold starts.
Old Feb 15, 2017 | 10:12 PM
elite1's Avatar
What OTS did you use? I have the car flashed with an OTS stage 3 and the secondary pump definitely turns on and off once warm.
How long did it take to clear the secondary pump once reflashed?
Old Feb 16, 2017 | 10:48 AM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Ran through the cycle a couple of times., with no luck I also have an OTS stage 3 with 1300 settings. I still can't get the same two you are having issues with, to say pass. I may end up throwing back on my stock injectors and reflashing a stage 1 OTS map. I put the stock exhaust on by the way, and of course I am not flooring it, it's just for emissions purposes.
Forgot to mention, my secondary pump also turns on without issues.
Old Feb 16, 2017 | 11:26 AM
elite1's Avatar
After 6 cold starts, my "Fuel Tank Ventilation" is now at "Pass" status.
Sounds like we are battle the exact same issue 02black33i.
Old Feb 17, 2017 | 05:39 AM
Wow!! But that's great news. Does your local emissions allow 4/5 readiness codes to pass? Mine does, so if i could get it to 4, I should be good. I'll keep at it.
Old Feb 17, 2017 | 08:25 PM
jhbrennan's Avatar
In Texas you can pass with 1 monitor showing "not ready".
Old Feb 17, 2017 | 08:26 PM
jhbrennan's Avatar
Congrats - perseverance paid off.
Old Mar 28, 2017 | 04:47 PM
DOOBEE's Avatar
DOOBEE is infamous around these partsDOOBEE is infamous around these parts
Just following up here to see if there was anything further? I wouldn't say the perseverance has paid off yet, I didn't see anyone with a clean slate yet, even with the stock exhaust. I'm assuming I'll have to pull the injectors and swap to another brand of tune again when its time.
Old Mar 28, 2017 | 07:26 PM
elite1's Avatar
Update: Still have the "Secondary Air Pump" not passing. I haven't really drove the car for the past month or so. When I find the time, I'll just take it to the dealer for them to fix the dang thing.
