Who makes the best exhaust for 997.2 TTS? Opinions wanted...
Old Jan 25, 2017 | 09:32 AM
99Gdzra's Avatar
99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute
Fit, form, and function, who makes the best exhaust in regards to PERFORMANCE for these 997.2 TTS's? I currently am running a Europipe with 100 Cel cats... I'm told it's great exhaust, but heavy and restrictive. I'm looking for opinions on a performance based setup, that's of good construction, good flow, and light in weight. Thanks for any and all opinions.
Old Jan 25, 2017 | 12:13 PM
Alankey's Avatar
Alankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant futureAlankey has a brilliant future
I would say Kline Inconel. I had Europipe and replaced it with Kline and love it!
Old Jan 25, 2017 | 12:25 PM
99Gdzra's Avatar
Did you notice a difference in performance? Still stock manifolds or did you switch to headers too? Thanks for your reply.
Old Jan 25, 2017 | 12:32 PM
Alankey's Avatar
Just exhaust changed, stock manifolds and headers. It seems to be happier to boost?
Old Jan 25, 2017 | 12:35 PM
99Gdzra's Avatar
Thanks for your feedback.... I'm sure it sounds better too.
Alankey's Avatar
It has a scream now and zero drone
Old Jan 25, 2017 | 12:39 PM
99Gdzra's Avatar
Very nice, I hope to get a nice tone with no drone. That's good news!
Old Jan 25, 2017 | 12:57 PM
locus's Avatar
locus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond reputelocus has a reputation beyond repute
I'd do Kline, if I pick up another porsche I'll get catless Kline + IPD plenum and call it a day. Oh yes COBB AP with custom tune.
Old Jan 25, 2017 | 01:40 PM
99Gdzra's Avatar
Stainless or Inconel?
Old Jan 25, 2017 | 02:26 PM
longboarder's Avatar
Putting cats right next to the turbos doesn't sound like the "best" regarding performance. Move the cats away from the turbos (i.e. move them to where the muffler would normally go) to reduce EGTs. As far as I know, only BBI does this. And yeah, fit form function all top notch with this bespoke exhaust.
Otherwise if you go catless there are a couple other high quality options.
Good luck.
Old Jan 25, 2017 | 03:15 PM
99Gdzra's Avatar
Good luck.
Always good info from you, thank you Adam. Any recommendations for catless?
Old Jan 25, 2017 | 03:44 PM
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
I'm convinced that Speedtech makes the best sounding exhaust for 997.2
And John is an awesome guy to deal with.
I'm super happy with my catless and mufflerless 3 inch race xpipe.
Old Jan 25, 2017 | 04:15 PM
John@SpeedTech's Avatar
We offer a great solution to consider. Our 3" X-Pipe can be used with the OEM cats and OEM tips. It ships with an adapter to taper down to the OEM cat diameter.
Or it can be purchased as a full 3" system with either our HJS Hi-Flow cats w/3" outlets or 3" cat bypass pipes, as 3llooi above is running.
An advantage of our unique design is that should you purchase the basic "muffler delete" for OEM cats/OEM tips and change your goals in the future, you can add our Hi-Flow cats (or bypass pipes) with 3" outlets or dual 3" tips or both (which would yield a full 3" system as pictured below). That option is on the table with SpeedTech plug and play parts by simply upgrading your existing system for less than the cost of an entire new system. In other words, it can grow with you.
Here are a few pictures to give you an idea. Our web site has several 997.2TT testimonials and we get nothing but positive comments from customers that purchase this system. We offer 6speed Member discounts, as well.
3" X-Pipe only w/ OEM cats and OEM tip outlets
Same X-Pipe configured as a full 3" system w/ dual tips installed
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Jan 25, 2017 | 04:20 PM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
I went with the Sharkwerks exhaust and it sounds great and has an even better price.
Old Jan 25, 2017 | 05:48 PM
SamboTT@ByDesign's Avatar
Haha you know what I'm gonna say! Here if I can help with anything buddy no matter what it is you decide I'll gladly help you out as much as I can.
