How do I know if my car has a dension unit installed?
Old Feb 17, 2017 | 04:11 PM
taylorgang's Avatar
taylorgang is infamous around these parts
08 turbo. I think PCM 2? I have an iPod cable in the center console and aux cable by driver footwell. The iPod plays music when I hook it up but I can't get the aux cable to work. Theres also a beltronics unit somewhere in the car so it looks like it had a radar detector installed. Maybe the aux was for that?
Is there a way to find out what system I have ?
Old Feb 18, 2017 | 09:29 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Press the cd button twice. If it says no CDC, you don't have aftermarket BTW. If the display shows GW AUX or BT audio, then you do. Next push the right radio **** and scroll to cd 6 and select `about` it will say the firmware version of what ever system you have.
Old Feb 18, 2017 | 03:43 PM
Dennis C's Avatar
It definitely sounds like you have some kind of aftermarket solution. The 2008 turbo came from the factory with PCM 2.1. There was not a factory option to add an iPhone/iPod cable to the OE system. Do you have telephone options available? Bluetooth perhaps? It could be Denison, Mobridge, or Nav-TV.
Old Feb 18, 2017 | 07:09 PM
taylorgang's Avatar
If I press the "CD" button it says "NO CD" -
I haven't been able to find any bluetooth options. There are phone options though. There are even phone numbers stored in the system.
The CarFax says "Interior accessory installed" by dealer in 2010. That's most likely what it was. Just not surre what exactly it is and what features are there. For now I've ordered an iPod -> Bluetooth adaptor so I can stream music with my phone.
Old Feb 18, 2017 | 07:51 PM
taylorgang's Avatar
OK so it's a TOOKI system.
I can't get my phone to pair with it though. It says the pass code is 6888 but it won't work. I have a Google Pixel on T-Mobile.
Found out how to get the AUX working too. Just have to press CD6 and navigate track list to select "AUX in"
Hopefully this helps someone else!
Old Feb 19, 2017 | 09:10 AM
Dennis C's Avatar
Typically with an aftermarket system, you won't see pairing options on the PCM screen for the bluetooth system. That needs to be setup through the aftermarket components. I had Mobridge in my car, and it was pretty easy. I never had the issue with the unit not taking the pass code.
