New I/C's = lower ET's but slower mph!
Old Mar 4, 2017 | 06:31 AM
  #31
Duckstu's Avatar
Duckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud ofDuckstu has much to be proud of
Can you post your logs up here? If you upload the logs to Datazap,.. you can see if it's pulling ignition timing.
http://datazap.me/
When timing gets pulled,.. EGT's go up a lot.
Falling over on it's nose after a gear pr two sounds exactly like the ECU is pulling timing.
There is a tendency for engines to experience a momentary knock on a hard lift-off the throttle,.., such as during a shift. This is one of the reasons it's CRITICAL to road test your tune with your tuner in the car after leaving the dyno.
Just doing 3rd or 4th gear pulls won't get you good results. The car may make great power when you roll into it on the highway,.. but in real world driving, (on and off boost, hard shifts, etc). the car may well be slow.
Old Mar 4, 2017 | 06:33 AM
  #32
vman932's Avatar
vman932 has much to be proud ofvman932 has much to be proud ofvman932 has much to be proud ofvman932 has much to be proud ofvman932 has much to be proud ofvman932 has much to be proud ofvman932 has much to be proud ofvman932 has much to be proud ofvman932 has much to be proud of
Originally Posted by 99Gdzra
Going to a local 1/8th mile track this evening to datalog 3-4 more passes on a different tune... I'll update post runs to show my findings.
Ugh! Car definitely isn't running up to par. Last year in the heat I ran a 6.74 @ 105! Tonight in waaaaay cooler temps I ran a 6.71 @ 102.8 mph. Not good. The car feels like it's fighting itself. 60' was pretty good... 1.54 but as soon as the car leaves it noses over and it feels like it stumbles, so unfortunately the journey still continues to find the happy spot with this car.
You said "different tune". Was this the same tune you had prior to the IC install? If not, I would definitely reload the tune you had prior to the IC install (the same one you were running the higher traps with) to eliminate that variable.
Old Mar 4, 2017 | 09:23 AM
  #33
99Gdzra's Avatar
99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute99Gdzra has a reputation beyond repute
Originally Posted by longboarder
Sorry to hear. Did you data log the new runs? Any differences?
By the way 1800 EGTs seem way too high. What is your exhaust set up and do you have cats?
I did data log both passes. I'm told the car is definitely pulling timing based on those egt's. It has Europipe WITH cats, the new AMS coolers, and tune.
Old Mar 4, 2017 | 09:29 AM
  #34
99Gdzra's Avatar
http://datazap.me/
I sent all my data logs and tune files back to Cobb Plano and I'm in lengthy discussions with them to figure this out... car is most definitely pulling timing as well as closing the throttle plate as egt's go up. They supposedly dyno tuned the car as well as road tested it prior to my picking it up.
On the freeway, the car pulls like a monster, but I attribute that to more air flowing across the coolers unlike drag racing starting from a dead stop. I had a reduced torque map they wanted me to load in the car but it's the same results.
Old Mar 4, 2017 | 09:31 AM
  #35
99Gdzra's Avatar
No, unfortunately they deleted that tune... I wished I still had it, because I damned sure would try it at this point. My level of frustration is growing each day.
Old Mar 6, 2017 | 07:26 PM
  #36
99Gdzra's Avatar
Quick update... I'm going to search out some 100 octane unleaded race fuel and try this same tune at the drag strip again. See if the higher octane changes anything? I'll report back when I find the fuel.
Old Mar 6, 2017 | 08:09 PM
  #37
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
^ Head down to Cresson at MSR. Texaco down the hill toward the track..They have a few flavors..
Old Mar 7, 2017 | 06:45 AM
  #38
99Gdzra's Avatar
I'm going to order a 5 gallon bucket of 100 octane unleaded to see if it makes a difference, then I'll order a drum if it works.
Old Mar 10, 2017 | 12:24 PM
  #39
99Gdzra's Avatar
Took the car back to Cobb yesterday and did some launch's using launch control... tuner determined the car is short shifting the 1-2 shift. 5,800 rpm's instead of 6,500 rpm's. The lil dip in the front end is because of that. He thinks the car is spinning the tires, trying to recover, it shifts into 2nd and closes the throttle plate at the same time. I did do one and manually shift the car, and that made it less noticeable but I'm not sure that's my problem?
Im going back to the track tonight if it doesn't rain to data log a couple more passes... we'll see if anything changes? To be continued....
Old Mar 10, 2017 | 12:28 PM
  #40
SamboTT@ByDesign's Avatar
L, if you're going to put the effort into getting some of that fuel you may as well get the highest unleaded octane you can. Like 109 or 104. More bang for your buck and more mixable. Hope they get you sorted soon buddy.
Old Mar 10, 2017 | 12:42 PM
  #41
99Gdzra's Avatar
I'll prolly get some MS109. But not tonight. They were supposed to call Jon... but they didn't. Just got what I believe is a go away you bug me answer.
Old Mar 10, 2017 | 03:10 PM
  #42
Getting a little frustrating, unfortunately I hate to say it but there is a separation there with new independent management. I really want to see you taken care of and I want to jump in but don't want to step on any toes. Give it one more try and at that point the team is just going to kick it in for you.
Old Mar 10, 2017 | 07:11 PM
  #43
bigrpowr's Avatar
bigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nice
you get an A for effort buddy. good luck tonight .. * no rain dance underway *
Old Mar 10, 2017 | 08:35 PM
  #44
99Gdzra's Avatar
Eh, I see my finding a new tuner pretty soon. I don't have patience for this stuff.
Old Mar 10, 2017 | 08:36 PM
  #45
99Gdzra's Avatar
Thank you sir! I wasn't able to make it out there this evening.. had a date with my CPA and that ran long. Oh well, next week we'll try again. It is what it is right.
