Looking for 997.1 Turbo MAF transfer function
Old Mar 15, 2017 | 06:49 AM
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
Was wondering if someone could help with this. I'm looking for either tabular data or a graph showing MAF airflow vs. voltage for the stock 997.1 meters. If anyone knows of one please let me know I would appreciate it.
Old Mar 17, 2017 | 08:30 AM
M3 Maestro's Avatar
Well since I couldn't find it I just made my own. Used Durametric to take the data required to build one. Now I know the limits of the meters for sure
Old Mar 17, 2017 | 09:29 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Haha, that is what I figured you would have to do. Never seen that data floating around anywhere before. Care to share your findings?
Old Mar 17, 2017 | 10:01 AM
M3 Maestro's Avatar
I will trade data for data LOL.
You have some room left. Upgraded vtgs at 22-23psi is close, WGTs at higher boost forget it, would need larger MAF bodies or MAF-less.
Old Mar 17, 2017 | 11:30 AM
SamboTT@ByDesign's Avatar
M3 you are a bad influence haha! Watch those rods. Will have you analyze the comparison after we are set and try MAFless so we can all geek out!
Old Mar 17, 2017 | 11:49 AM
M3 Maestro's Avatar
Excellent point, there will be plenty of other limits like the rods. I'm merely only referring to the MAFs themselves . Hopefully nobody thinks "MAFs have some room" is an invitation to a free for all .
Honestly in the case of my setup I should be saturating the map sensor slightly before saturating the MAFs and about 80ish% inj duty on E70 @7krpm. So I think I will be done there. The hp/$ gain will go exponential after this .
Yeah I would find it interesting to try the 2 different calibrations back to back.
Old Mar 17, 2017 | 12:55 PM
when do you see the MAFs max out ? I thought each one was good for 400-450hp worth of airflow.
#TeamAIM
Old Mar 17, 2017 | 01:25 PM
M3 Maestro's Avatar
It depends on a few things like your fuel, the way you phrased it assumes a bsfc. So lets speak purely in mass flow. I don't have the all the data yet to make the call of the "ultimate" limit. I know where I am comfortable, and that's at ~37lbs/min each. From 37lbs to 42lbs zone its fairly steep, I just don't have the data yet to know for sure.
If you have data with GT30s running MAFs in the area of 25+psi I would gladly look at it Most of my data collected from different 997s last year stop around 22-23psi with various VTG upgrades.
I will also add there is a expected variation in airflow measurement accuracy of 3% from part to part.
