dual injector solutions
Old Mar 28, 2017 | 07:22 PM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
Perfectly happy with my factory 997.1 intake, but considering going to dual injectors. I have seen several of ya'lls bad *** intake setups, but I am wondering what is the lowest cost way to run dual injectors? I am not looking for a better intake manifold.. just two bosses for injectors
Old Mar 29, 2017 | 07:31 AM
if you are using 997tt intake I don't think you can do this because its plastic. so unless you make a spacer to sit under it for the second set of injectors, but that may just set the intake too high up. most people are using the twin injector stub manifolds from magnus. I have a second set of rails above the first set, set higher up.
#TeamAIM
Old Mar 29, 2017 | 08:18 AM
Ya, Magnus + GT2 is probably the way to go. I really dont *need* it, but would like to get away from a single 2000cc injector.
Old Mar 29, 2017 | 08:20 AM
I cant see how you would do it with a stock 997TT intake, I don't there is enough space for a spacer.
#TeamAIM
Old Mar 29, 2017 | 08:21 AM
Yep, that was my assumption.
Old Apr 2, 2017 | 12:15 AM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Old Apr 2, 2017 | 03:04 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
ESmotor built a great intake monifold that run 12 injectors .. you can PM them to check
Old Apr 2, 2017 | 03:08 PM
rix's Avatar
rix
The pics of my intake above is the Esmotor setup. It uses ISC/Magnus lower plenum for dual injector, GT3 RS 4.0 upper, and ES Motor billet center section. After mock ups for fitment I had everything coated in that ceramic/matte black by Driversource in Houston.
Old Apr 2, 2017 | 04:16 PM
Looks inexpensive
Old Apr 2, 2017 | 10:28 PM
rix's Avatar
rix
Originally Posted by jordonmusser
Looks inexpensive
its not so bad when you spread your costs out over 2 years like I have .
Old Jul 27, 2018 | 04:11 AM
Tareq's Avatar
Tareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant futureTareq has a brilliant future
Just curious to learn if there is any benefit running the secondary injectors higher than the first set? Wouldn't it be easier to get the Magnus stubs?
Thanks!
Old Jul 27, 2018 | 06:09 AM
rix's Avatar
rix
No benefit to running them higher other than packaging. Closer to the intake valves the better.
Old Jul 27, 2018 | 06:16 AM
Tareq's Avatar
Thanks for the input.
I know it's hard but Is there a rough estimate to when one would need to run a dual injectors set up?
I'm currently running ASNU 1500's, would like to know how much power should I expect before needing a dual set up.
Thanks!
Old Jul 27, 2018 | 06:21 AM
rix's Avatar
rix
Depends on the density of the fuel you’ll be running. On gasoline you’d probably never run out of fuel. For Ethanol more like 1050-1100whp tops. The ID1700s are generally claimed to max out around 1200whp.
Those are e85 numbers, assume a little less on higher ethanol content.
Old Jul 27, 2018 | 06:27 AM
rix's Avatar
rix
I should probably add - while it’s possible to get those numbers out of a single set I wouldn’t call it a good idea. If anything goes wrong with the fuel system to lower the maximum available output you could find yourself with a seriously expensive situation.
I would suggest building at least 20% headroom into it if not more. Fuel system tends to be the thing people always overlook. While not as sexy as some other parts, the engine only uses air and fuel. Why we spend so much trying to get air into the engine but try to run the fuel system at 110% is one of those mysteries of life.
