Gearbox question?
Old May 15, 2017 | 01:24 AM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
The early torque is certainly the *everything* killer. Stock rods, transmission, clutch, etc. I'm currently limiting power output on the low end to protect my transmission or it would probably make 1200ft/lbs peak.
Old May 15, 2017 | 01:42 AM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Right, I also hope the Carrillo's will hold it in time.
In the other hand, what a great feeling enjoying early torque!
When I test drive friend's F12 or Lambos (N/A) they feel slowww...
1200ft/jbs
What about your turbos? (size, flowing rate)
Old May 15, 2017 | 02:21 AM
rix's Avatar
rix
I'll be posting about the turbos pretty soon but they are 65lbs/minute of airflow each.
Old May 15, 2017 | 02:53 AM
K24F's Avatar
Ok, mines are rated 57lbs/mn.
For reliability boost target is "only" 1.65-70Bar (24psi), reached at 5200rpm with 1.4Bar (20psi) at 4000rpm and 1Bar (14 psi) at 3000rpm by cold weather (<10°C).
For such torque you may run at least 30psi?
Old May 15, 2017 | 02:55 AM
rix's Avatar
rix
Yeah around 30. I am watching turbo shaft speed more than boost though. I'm not really sure how high it was when I was running the car this weekend, I need to look at the logs.
