Sponsored by: Bears Transport
Rix 997.1 Turbo Project 121
Old 08-17-2017, 01:32 PM
The Bogg's Avatar
Awesome thread, Rix. I don't know what you do for a living but if you pay as much attention to detail at work as you do for this build then you would be the best employee EVER!
  #152
Old 08-17-2017, 01:34 PM
rix's Avatar
rix
rix is offline
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Always. I didn't pay much attention to this - that's why it took so long
  #153
Old 08-17-2017, 01:42 PM
SamboTT@ByDesign's Avatar
Keep it up Dan!
  #154
Old 08-22-2017, 08:49 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Awesome results, and really cool project. Keep up the good work!
  #155
Old 08-22-2017, 12:14 PM
rix's Avatar
rix
rix is offline
Thanks guys. I'm going to add a few sensors, do something with the exhaust to try and quiet it down a bit, and a few other things here in the next couple of weeks. It hasn't really been on the dyno in anger yet, so hoping to get a couple of angry pulls to see where it's at as well. Then I'll be racing at Texas Invitational on October 7/8, I should get some 60-130 and lots of video as well.
  #156
Old 08-23-2017, 08:35 AM
Originally Posted by rix
What spring are you using in it? The 1.5 or the 3.0psi one?
honestly I don't remember because it was so long ago. I believe its the 3psi.
#TeamAIM
  #157
Old 08-25-2017, 12:09 PM
jordonmusser's Avatar
jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !jordonmusser Is a GOD !
rix- what is your exhaust setup now? mine isn't very loud.. at least, in my mind. I feel a little sheepish when I drive it to work @ 7am, but its not horrible. Ive been pulled over plenty of times (no tickets!) and no complaints about the exhaust, just me driving like an ******* in general
  #158
Old 09-15-2017, 11:43 PM
rix's Avatar
rix
rix is offline
Originally Posted by trbofvr
Really nice!! Do you happen to have the dyno charts with RPM instead of speed?
No I don't. They didn't have an RPM pick up on my car due to something with the M&W ignition and there being an adapter we didn't have. I have been hoping to get my car back on the dyno and do a little more tuning, but looks like the next thing is going to be Texas Invitational in October.
I just got the trailer today.
  #159
Old 09-16-2017, 02:12 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Keep it up bro ! How is the clutch doing ??
I have RPS and it's bad in low rpm driving but hold fine !
I have almost the same setup you have
good luck buddy
  #160
Old 09-16-2017, 02:22 AM
rix's Avatar
rix
rix is offline
Ive got a muffled BBI x pipe right now. I think ours sound pretty similar. They aren't that loud, but yeah definitely the neighbors are going to hear it.
  #161
Old 09-16-2017, 02:24 AM
rix's Avatar
rix
rix is offline
good luck buddy
Clutch feels the same as when I first drove it.
  #162
Old 09-16-2017, 10:34 AM
how many miles on it?
#TeamAIM
  #163
Old 09-16-2017, 08:44 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Any Pbox times yet?
And how are you liking those internal gates? Any problems with high boost?
  #164
Old 09-18-2017, 01:53 AM
rix's Avatar
rix
rix is offline
About a thousand.
  #165
Old 09-18-2017, 02:00 AM
rix's Avatar
rix
rix is offline
Originally Posted by TT.BRN
Any Pbox times yet?
No boost problems with the turbos. It's actually easier to run higher boost than lower boost with a wastegate system.
Say you're running 30psi and the wastegates are mostly shut. Air is flowing through your turbine, then out the exhaust. A tiny amount of air may be flowing through the wastegate. If you're running 15psi, the wastegates are partially open bypassing air away from the turbine. Eventually you'll hit a point where you can't run any lower boost, due to the wastegate not being able to flow enough to divert away from the turbine.
In the past your usual OEM internally gated turbine housing didn't have a very big internal gate, and the setup was more of a compromise from the start, although that is changing now that turbocharging is becoming 'socially acceptable' again in the car market.
The TiAL internally gated housings are designed with much larger internal gates than are typical, and use a novel (patented I believe?) design that swirls air around the outside of the air that is coming through the turbine which raises turbine efficiency. If you talk to the designers of the parts they will tell you the setup actually works better than a traditional external wastegate setup. I'm not really qualified to give an engineering dissertation on it, but it sure works well on my car which was enough to convince me.
Quick Reply: Rix 997.1 Turbo Project 121
