P0003 & p0203
Old May 10, 2017 | 11:42 AM
Saint Ari's Avatar
Saint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud ofSaint Ari has much to be proud of
P0003 & p0203
I was on vacation and havent driving the car in over a month.
Started it earlier, it idled kinda funny and after a few seconds the check engine light started to blink.
Switched off the car and the AP found both P0003 and P0203
P0003 Fuel Volume Regulator Control Circuit Low
P0203 Injection value, open circuit
Would appreciate some insight from all your collective wisdom.
Car is a 997.1 TT.
Thanks in advance.
Old May 10, 2017 | 12:54 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Did you check fuel pressure?
Old May 11, 2017 | 12:24 PM
Edgemonty007's Avatar
Edgemonty007 has a spectacular aura aboutEdgemonty007 has a spectacular aura about
Sounds like battery to me. Did you have the battery on a tender while not in use?
Old May 11, 2017 | 10:15 PM
Saint Ari's Avatar
I did a reset a couple of times and it just sorted itself out.
Perhaps injector #2 was stuck or something.
Old May 12, 2017 | 12:25 PM
Macster's Avatar
Could be a lazy injector.
Running a tank or two of Chevron gasoline could help. Or you could go big and dump in a bottle of Techron into the gas tank then fill the tank and drive the car.
I use the bottle that treats 20 gallons even though the fuel tank of my Turbo is ~16 gallons.
It is SOP to if you notice any improvement to run a 2nd bottle of Techron but whether you notice an improvement or not I'd run 2 bottles, one after the other.
If you use Techron out of a bottle the recommendation is to change the oil/filter afterwards. The oil gets a bit more contaminated using concentrated Techron and the last thing these engines need is more oil contamination.
