Sponsored by: Bears Transport
my logs 65 mm turbos
Old 05-14-2017, 07:01 PM
Slategery997turbo's Avatar
Slategery997turbo is an unknown quantity at this point
how does the logs look
datalog16.csv
datalog14.csv
Old 05-14-2017, 09:14 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Upload them to datazap.me ... Easier to view
Quick view seems you have knock between 5500-5700 .... What fuel you use?
Old 05-14-2017, 10:07 PM
65
93fuel
Old 05-15-2017, 10:10 AM
what tune?
#TeamAIM
Old 05-15-2017, 10:39 AM
Sambo
Old 05-15-2017, 11:19 AM
SamboTT@ByDesign's Avatar
I heard my name
Sent you a new map this morning buddy. Just trying to give you as much as possible and keep everything happy. I have a feeling your car is going to be a little stronger and we can revisit when you have full summer blend pump gas. We might be ready for ethanol now after the one I just sent.
Old 05-15-2017, 12:45 PM
M3 Maestro's Avatar
M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !M3 Maestro Is a GOD !
Slate I think the timing corrections you are seeing are probably mainly fuel and or intake temperature. We(I get my calibrations thru Sam as well) ran my 93oct file without much issue but I was logging in cooler weather.
What was the ambient temperature and pressure when you logged these? I recommend you select those channels on the data logging options. I can look up any of my logs and see what the conditions were when I collected the data.
Old 05-15-2017, 01:23 PM
He is on 997.2 IC's too so on higher boost it does not like it as much. Almost there
Old 05-17-2017, 08:54 PM
now e85
datalog19.csv
Old 05-18-2017, 07:20 AM
M3 Maestro's Avatar
The e85 baseline file looks good as your starting point. Based on your intake manifold temps, your ambient temperature is pretty high. Given those conditions, your MAFs say those 65mm turbos move pretty good air at that boost level. If your ambient temperature drops 30-40degress you will be shocked at the level of performance increase. Sam will get your car where it needs to be, be patient and work thru it.
Old 05-18-2017, 07:40 AM
Yes Sam is a gentleman. Allways helps me when there's a
problem this car has been a problem pit and we been addressing a lot of problems don't know why but it's like
fighting me to the end lol yes when I logged the car
yesterday it was 80 degrees out and the car airintake temps
where up there
Old 05-18-2017, 07:43 PM
bigrpowr's Avatar
bigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nice
i run E85 and 63.5's , and i figure my stock intercoolers are a big nuisance. i got some aftermarkets D088 units, i assume they should help.
