PCM 3 retrofit issues!
Hi guys, I recently retrofitted PCM3 (to my 2007 997 Turbo) with the help of the thread here and from iandiman (your help, patience and perseverance was amazing! without your guidance I would not be able to have done this)
The only issue that I (and some others) have, is that my Trip functions on screen 2 and 3 do not work (please see attached pics) has anybody else experienced this, and if so were you able to fix it?
Hi trbofvr, no other issues. Took time to gather all the correct parts and documentation to perform the retrofit, but once started went easy and was enjoyable. The first time you switch it on and everything works is pretty awesome!
