Dumb passenger window issue.
Old Jun 19, 2017 | 05:45 PM
Macster's Avatar
Originally Posted by trbofvr
Anything to make the passenger window go up all the way instead of like getting it half way up manually and then pressing again to close it automatically past that?
With my 2003 Turbo coupe just a quick press of the raise button has the window going all the way up even if the window starts out all the way down.
If your car's windows don't behave this way maybe there's a "komfort" setting that enforces this behavior and this setting may be changed via either the factory diagnostics computer or perhaps Durametric?
Old Jun 20, 2017 | 10:25 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
It is a safety feature that is suppose to keep from trapping a body part in the window.
Old Jun 20, 2017 | 09:03 PM
trbofvr's Avatar
trbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud oftrbofvr has much to be proud of
No its not its dumb. Other cars have that and it works based on pressure back on the window
Old Jun 28, 2017 | 06:59 PM
DaveCarrera4S's Avatar
DaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond reputeDaveCarrera4S has a reputation beyond repute
Originally Posted by Bobbyfali
I was going through my manual, looking for unrelated issue and stumbled across them saying the passenger window only auto ups after half way.
I thought it was screwed up, requiring a trip to the dealer. THANKS FOR THE ABOVE!!
Old Aug 24, 2017 | 09:04 AM
The Bogg's Avatar
Originally Posted by Webspoke
There is a window switch in the door latch mechanism can cause the window cracking problem. You have to install a new latch mechanism to replace it, as the switch is not available separately.
Is this a diy type of thing? My driver side window "cracks" when I pull the handle but then it pops back up sometimes before I close the door. In that case I have to reclose the door or manually crack the window and then close the door. I'm guessing it's a sensor/switch issue. Any idea what the part number is by chance?
Old Aug 24, 2017 | 09:19 AM
Similar to my issue. If the car (997.1 Turbo) is not or was not running, the window goes all the way up whenever the driver door is opened. If the car is running or was just turned off, the window drops properly for closing the door. WTH (what the heck). So I doubt it is the switch, but rather the ECU program is messed up??? Anybody else seen this? Any ideas to fix?
