DIY: Brake Pad Change
Old Aug 25, 2017 | 06:29 PM
nzskater's Avatar
nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !nzskater Is a GOD !
Actually looking at it, the part number is the same.
The parts catalog is available on Porsches website.
Old Sep 1, 2017 | 11:20 AM
cam99's Avatar
cam99 is infamous around these partscam99 is infamous around these parts
Anyone know the torque values for caliper bolts PCCB rears?
Old Sep 1, 2017 | 11:33 AM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
Here you go!
Old Sep 1, 2017 | 07:56 PM
02black330ci's Avatar
02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !02black330ci Is a GOD !
Originally Posted by VID997
Here you go!
NICE!!! You sir get some rep points, thanks for posting this!!
Old Oct 19, 2017 | 07:45 AM
HardHitter's Avatar
HardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to allHardHitter is a name known to all
Still haven't gotten around to doing this so I am going to end up bringing it to a shop once I get a quote. Just don't have time to DIY
Anyway, I've purchased the brake pads (front & rear) and I've purchased the caliper bolts for the rear. The only other items I believe are the damping plate and wear sensors.
I'm going to talk to the shop and see if they will just reuse the damping plates (shouldn't be a problem right?) or wear sensors, but they did say that they like to replace the wear sensors. When I google the sensor part number (99761275400) I get a few options. Some of them are charging $11 but Sonnen is charging $31? What is causing that huge price difference and am I safe just buying the $11? How many do I need to purchase (assuming 1 sensor per wheel @ 4?).
Old Oct 21, 2017 | 05:43 AM
BLE2011's Avatar
BLE2011 is infamous around these parts
I replaced my brake pads last weekend. Very easy. I bought the brake pad wear sensors from rockauto.com. The fronts were $8 each and the rears were $12 each. I’m glad I bought them because they are fragile and 2 broke upon removal.
Old Oct 21, 2017 | 08:29 AM
HardHitter's Avatar
How many sensors per wheel? 1? So I'll need to buy 2 front and 2 rears?
Old Oct 21, 2017 | 01:46 PM
BLE2011's Avatar
There is a sensor for each brake pad. 2 in the front and 2 in the back (they are then split into 2 - one for each brake pad). The front and back have different length wires so they are not interchangeable.
Old Oct 26, 2017 | 10:45 AM
Johnny DB's Avatar
Won't take you very long...
Old Nov 1, 2017 | 09:53 PM
HardHitter's Avatar
From UROParts, could you let me know the part # you ordered and how many quantities of each?
Old Nov 2, 2017 | 12:59 PM
nzskater's Avatar
One sensor part per wheel. Each sensor has two tails that run to each pad. 4 parts needed in total
