Center lock wheel bolts
I just got some new center lock bolts in black and they did not come with the cone washers or the other hardware So do I use the old ones and is there any problems with doing that thanks Mike
Not that we dont have excellent members here, but since you have one central bolt holding your wheel onto your car, i would suggest you call your dealer and possibly go over to the parts department to show them what you have in hand.
Either that or call the place you opurchased the new bolts and get the info there.
I have center locks and am running stock equipment but if I were to make a change on the bolts or wheels, I would be sure that Porsche blessed the parts.
Just my 2 cents, and I will admit, I am one to error on the side of caution when it comes to my life
When I ordered a set of black bolts, all the necessary hardware/gaskets came with them under the part number. I know the red ones don't come with that but the black did.
Call Suncoast Porsche, they will be able to help you get what you need
+1 suncoast
Ditto...mine came with the necessary hardware as well and were sourced at Suncoast as well
