996/997.1 TT High Performance Bearings and Headgasket
Old Sep 20, 2017 | 10:54 AM
Phoenix*'s Avatar
Phoenix* is infamous around these parts
Hi Gents,
Could any of you guys advise on part numbers for high performance 996/997.1 main and bigend bearings, along with a capable MLS 1.3mm Headgasket?
And also, who I can source these parts from...
Our current engine has Glyco mains and Clevite big-ends. I'm struggling to find a source for these bearings again, but was hoping to upgrade to better bearings, if possible.
I have searched endlessly on the web, with no success.
Any assistance would be greatly appreciated.
Thank you.
Regards.
Old Sep 25, 2017 | 07:41 AM
997 and 996 big end bearings are not the same. best source for 997 bearings is the dealer.
#TeamAIM
Old Oct 2, 2017 | 06:43 PM
Q8_TwinTurbo's Avatar
Q8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud ofQ8_TwinTurbo has much to be proud of
I would suggest you do the following;
Buy OEM bearings and send them to WPC for their WPC treatment.
They will have less friction and last much longer.
As for a better designed MLS head gasket. You can buy the EVOMS "HellFire" Head Gasket set. The thickness is 0.040" = (1.016mm).
You can also use the EVOMS 10mm Head studs.
Good luck with what you go with.
Old Oct 7, 2017 | 11:28 AM
brnrdtns's Avatar
brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !brnrdtns Is a GOD !
EBS Racing in Reno has a good selection and contacts.
Old Oct 8, 2017 | 04:05 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Did not test upgraded bearings !
But used factory parts and work perfectly , I even ran OEM head gasket with 1000hp setup and it work very well , only forge Rods / evoms head studs !
