Another ES650 997.2TT PDK - 697 awhp stock VTGs
Old Dec 18, 2017 | 03:45 PM
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
Originally Posted by DanWeber
Great results! Congrats!
thanks Dan!
Old Dec 19, 2017 | 06:43 AM
thegame's Avatar
thegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond reputethegame has a reputation beyond repute
Just curious why I have seen some 997.2 builds with upgraded 68mm VTG turbos make even less power than this package? Is it because of the meth, it allows a more aggressive tune that is still safe? I am guessing the stock turbos are maxed out as well as the fuel system with this bolt on/meth package?
Maybe with a turbo upgrade you would then need rods/dodson clutches for the PDK as well as an upgraded fuel system to fully take advantage of the turbo upgrade?
Old Dec 19, 2017 | 07:54 AM
longboarder's Avatar
Great question, Ali can chime in as well but the stock 997.2 turbos are large and can flow more air/power than the stock fuel system can handle, so when you get the best Cobb tuner on the planet plus a good meth system flow, the man himself Emre can achieve spectacular results.
Old Dec 19, 2017 | 08:44 AM
thegame's Avatar
Makes sense!
Old Dec 19, 2017 | 10:04 AM
BHR997.2TT's Avatar
BHR997.2TT is infamous around these parts
Although the turbo wheels are stock, I believe Ali has done some custom porting to the turbos to help get these results. I am sure he can chime in to clarify.
Old Dec 20, 2017 | 02:45 AM
3llooi's Avatar
yes gents
the stock fuel system is the limitation here.
stock Turbos still has room in them.
although my turbos are ported and polished to correct some flawed air channels from factory and enhance overall air velocity; i don't think they added a ton of real whp. Could be around 20whp max?
we are at the limit of the fuel system. Everything else is within control for Emre to make it safe running tune.
we'll see what's next
Old Dec 20, 2017 | 02:47 AM
3llooi's Avatar
IMHO.. yes. I won't do a turbo upgrade or change the turbos unless I do a fuel system + built engine + clutches for the PDK.
Old Dec 20, 2017 | 02:49 AM
3llooi's Avatar
Before the port and fine tune
the car ran the below numbers
Old Dec 20, 2017 | 04:29 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello guys,
To be honest, VTG upgrade doesn't make worthy difference on 997.2TT because the stock turbochargers are working very effective till the end of fuel system.
So you can max out stock fuel system with stock turbochargers if you tune the ECU correctly.
We upgrade the turbos when stock turbochargers are worn out or need repair.
I would ofcourse like to sell more VTG upgrades on 997.2tt platform but i don't want to lie here
Emre
Old Dec 20, 2017 | 05:07 AM
Jose Hernandez's Avatar
Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !Jose Hernandez Is a GOD !
So, has anyone solved the fuel limitation? I was one of the probably few persons that bought an upgraded fuel pump( not saying from whom) and it was a mess...
Old Dec 20, 2017 | 07:08 AM
3llooi's Avatar
Originally Posted by Emre@Esmotor
Hello guys,
Emre
Thanks Emre
Old Dec 20, 2017 | 07:09 AM
3llooi's Avatar
I am sure Emre well
Old Dec 24, 2017 | 03:43 PM
3llooi's Avatar
I would like to know what's the brand you got.. if u don't want to share in public, pls PM me.
as a community of enthusiasts, I believe we should share the negative experiences in an objective matter.. not only the positive things
Old Dec 25, 2017 | 01:07 AM
BRN997GT3's Avatar
BRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant futureBRN997GT3 has a brilliant future
great power mashalah
Old Dec 31, 2017 | 07:28 AM
I have an older post relating my troubles...srm fuel pump... I don't want to sound like a basher
