997 Turbo 20" Avant Garde Front Wheel fit incorrectly
Old Jan 25, 2018 | 09:48 AM
Get Your Wheels's Avatar
Get Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to beholdGet Your Wheels is a splendid one to behold
Originally Posted by mjgoldner
If you dont mind, could I call you ?? Who should I ask for??
you can reach me at my direct line - (562) 275-8268
- Josh
Old Jan 25, 2018 | 05:18 PM
Lazu's Avatar
Lazu is infamous around these parts
Originally Posted by Get Your Wheels
How much clearance do you have on the front brake caliper and inside fender lining? If there's enough space up front, then we could build a 20X9 with a much higher offset. If not, pretty much standard across all wheel manufacture is 8.5 +45 and SOME can go 9 +47 and few 9 +52 and higher.
go to know i can do a +45 on a 8.5 can i do a +45 on a 20x9 front.also what the most aggressive i can go on the rears with a 20x12 or 12.5 thank you.
Old Jan 25, 2018 | 05:21 PM
With the M610, you can go from ET+15 to ET+60 as long as there is enough back pad to work for the 5X130 bolt pattern.
Old Jan 25, 2018 | 05:54 PM
Lazu's Avatar
would that be the same with any wheel let’s say the bbs lmr’s in a 20x12 can i do a et40 or that’s not possible.
Old Jan 28, 2018 | 08:22 PM
mjgoldner's Avatar
mjgoldner is infamous around these parts
Originally Posted by Harry Da Hamster
just a little more negative camber up front and you'll be fine
How much less Camber can I get with stock bearing plates? Also I was planning on using H&R lowering springs.
Old Feb 7, 2018 | 12:07 PM
cyclrder's Avatar
cyclrder is infamous around these parts
that wheel bows out from the center.. the opposite of a deep dish. I don't really mind it but it is aggressive..... as comparison.. a GT2RS would be a 9inch wheel with a 47mm offset.
But that being said.. a GT2RS has completely different carbon fiber fenders that have an extension molded into the fender.. GT3RSs have a stuck on piece of extension.
simtiaz
Dec 25, 2016 11:01 PM
jordonmusser
23
Sep 12, 2016 07:03 PM
Get Your Wheels
BMW Vendor Classifieds
Sep 5, 2013 04:00 PM
